Commuting cyclists ...
[Closed] Commuting cyclists and their mechanicals.
Hey all, I am doing a bit of research into the bike related mechanicals people have on their daily commute. Trying to find the most common problems people have to fix or get fixed I.e. punctures, gears slipping etc.
So
Whats the most common breakage you have on your bike?
What do you do do when it happens? Fix it yourself? take it to a bikeshop?
Feel free to post up stories and experiences related to this too.
Any feedback would be most grateful.
Posted : 28/11/2012 6:14 pm
Whenever I have a mechanical I simply swap bikes with my domestique.
Posted : 28/11/2012 6:26 pm
Snapped chain - I ride a folder that is prone to it. Fix it myself
Puncture - Ditto
Bolts loosening - Ditto
Only thing I ever go to a bike shop for is headset replacement
Posted : 28/11/2012 6:28 pm
None, tbh. I mean, there's minor things like rubbing brakes, gears getting a little past it but nothing that can't be tolerated for a little while then fixed when I can be bothered. But then my commuter is a bit of a tank.
Posted : 28/11/2012 6:32 pm
Nowt really atm - pompino singlespeed with scwhalbe marathon tyres that are relatively puncture proof on the roads. Change the brake pads now and again and that's it.
If I have proper CX tyres on it for whatever reason I normally pick up the odd puncture.
Posted : 28/11/2012 6:33 pm
chain snapping and flats.... fix them my self
Posted : 28/11/2012 6:35 pm
my gears do get a bit sloppy but i rarely clean teh comuter so it suffers a bit, i only replace the drivetrain every couple of years
grips wear out quick as i do 200 miles a week
schwable marathon plus means no punctures!
i didnt fit the little retaining pin properly on my v brakes cartridge pads, a pad fell out
v brake noodles get shagged quicly
its rigid, 1x9 and has cheap but solid components, not much to go wrong!
Posted : 28/11/2012 6:36 pm
Not even had a puncture in 4 years, then in the last week or so I've had a knackered freewheel and then I dropped a crank bolt and the crank came off.
Bah. LBS both times.
Posted : 28/11/2012 6:58 pm
A majority of what i see others with is snapped chains an punctures
We run a pair or alfined cross bikes with schwalbe marathons , disks and full guards
I also operate a commuter bikes comes first in the maintainance pile.
Its no fun walking to my gaff
Can't actually remember the last mechanical. I wear things out quite a bit.
Bike is singlespeed running heavy duty rings and chain so they rarely just snap if you keep on top of maintenance.
Tyres are armoured and I run heavy duty tubes so punctures are rare. The last one I picked up a 3" nail.
Spokes break but you can just ride on anyway with a reasonable set of 32 spoke wheels.
Bolts come loose occasionally on things like my mudguards.
In general my bike is simple, cheap and built for reliability at the expense of weight. I give it a check up just before winter kicks in (as mechanicals in the cold are no fun) and then service and replace bits in spring once the gritters have gone away.
Posted : 28/11/2012 7:02 pm
I don't want to tempt fate but so far I have been pretty lucky (another vote for Marathon Plus)
Generally I just need to tension the chain (singlespeed). I can't imagine this is related but I have had a rear wheel coming loose incident ๐Ÿ˜‰ Popped in too nearest bike shop to ask for a spanner.
Other than that one puncture and replacement of brake pads which I see to myself. Oh, and my latest bodged mudguard tends to come loose.
Posted : 28/11/2012 7:30 pm
Mini vee brake arms get gummed up/a bit corroded and need lubing and adjusting fairly regularly. Fix it myself.
Punctureproof tyres so no issue there and single fixed gearing also for the win.
Posted : 28/11/2012 8:03 pm
Mostly, we see punctures, often caused by worn/perished tyres. Worn out brake pads are probably next, followed by buckled wheels and broken rear axles. Outside of that, most other failures are due to lack of cleaning and maintainence, resulting in everything operating in a sea of grinding paste.
Posted : 28/11/2012 8:07 pm
Nothing so far (touches wood). I maintain it pretty well - regularly (well, fortnightly is regularly for me) cleaned and lubed, bolts checked, gears/brakes adjusted etc. 100 miles a week in general, although not so much the last couple of weeks!
Posted : 28/11/2012 8:10 pm
Mechanicals I have are mainly punctures - fixed myself roadside with a spare tube.
Have had one broken crank (snapped) - phone call home to pick me up from work then new cranks fitted by me.
One pedal coming loose (thread in crank arm stripped), limped home and new cranks
One snapped chain - phone call home.
Broken spokes - ride on and fix whenever
brake pads worn - ride on and fix whenever
Snapped handlebars (25 years old!) - limped home with one sided bars
Wheel rim split - limped home and spare wheel fitted
All in 12 years, 120 miles/week commuting so not that bad really
Posted : 28/11/2012 8:15 pm
Semi regular jobs on the commuter for me are/have been fixing punctures, freeing stuck v-brakes, changing brake pads, tightening bolts, tightening up cables, occasionally replacing cables/outers.
Of these it's really only punctures that ever need sorting on the spot.
I'd imagine a lot of LBS trade though is stuff that people on here would tweak when it stops working well, but that most people will just take to the shop when it stops working altogether.
When I was doing a bit of commuting (c170 miles pw), only bother was worn drivetrain and punctures (usually through worn out tyres).
Fixed everything myself, tho it was usually left caked in road grime and associated filth.
Frame has now cracked. Loved that bike.
Posted : 28/11/2012 8:20 pm
All generally done at home, but the commuter generally doesn't need much love,which is good as I have no enthusiasm for polishing a brompton.
Having said that, the Sturmey Archer hub died yesterday (seized) and i can't be bothered with that, plus its only a year old, so that will be going back to the LBS.
The other shop worthy mechanical was when the back end fell off the brompton (snapped pivot, bent stays) as i overtook a bus. That went to the LBS too.
Punctures used to be common before i got some marathon plusses.
Posted : 28/11/2012 8:49 pm
the odd puncture, including one where a nail went through my rim.
Jockey wheel fell off once too ๐Ÿ˜ณ
Posted : 28/11/2012 8:54 pm
Single speed, so no drive train issues ever.
I put latex in the inner tubes so punctures seal themselves, so don't get those either.....
Posted : 28/11/2012 9:28 pm
had a puncture today. Recently swapped from backpack back to panniers, forgot to move my tyre levers across. Used two forks from the work kitchen, why do I only get punctures when I'm late off?
mechanicals get fixed road side, I also try to help other cyclists where I can.
Posted : 28/11/2012 9:31 pm
 hh45
Punctures, 1-2 pa, mainly a sign that tyre needs replacing,
Only serious one was a rear rim wearing through. Limped home and got a spare bike out. Bought a new wheel from a LBS.
That is in 10 years, 50+ miles per week. Its not a bad life cycling to work!
Posted : 28/11/2012 10:46 pm
 mrmo
had the tyres disintegrate this week, monday lost the front and tuesday the back, and i mean disintegrate the rubber peeled off the carcass, but they had done a good few thousand miles and were light tyres so to be expected, other than that the odd puncture, but i tend to view punctures as a warning that the tyres need changing.
Posted : 28/11/2012 10:47 pm
 ton
30yrs commuting. snapped chains and punctures. fix em myself.
oh, and a split rim about 15yrs ago.
Posted : 28/11/2012 10:53 pm
I'd suggest that this audience of mountain bikers will be a pretty self-selecting audience of competent trail fixers/bodgers. Whether you'd have the same answers from a more casual, commute-only cyclist, I don't know. Doubt it though... most bike shops seem to do a good trade in fixing basic punctures.
Posted : 28/11/2012 10:55 pm
Brompton commuter here.
Lots of punctures led me to using slime in the inner tubes. Not sure whether its the volume of glass on Manchester roads or a Brompton thing. Only other mechanicals in two years have been consumables including new chain and brake blocks. I do all my own maintainence and repairs.
Wouldn't swap cycle commuting for driving if I was paid to drive. Love it.
Posted : 28/11/2012 11:05 pm
1 snapped spoke and 1 puncture in 2 1/2 year
Posted : 28/11/2012 11:12 pm
punctures and worn out brake pads mainly. I try and keep on top of the maintanence: single speed pompino with front disc makes this easy.
a few times i have had the embarassing problem of getting a punture and pulling out an entirely innapropriate tube. 2.4 tyre 23c tube etc! phone call home then!
old bike was a nightmare compared - loose ball hubs and BB needed rebuilding monthly through winter! ๐Ÿ˜ฏ
Posted : 28/11/2012 11:21 pm
3000+ miles commuting this year - one snapped spoke (crappy roads + poorly tensioned wheel) got home before I knew I'd done it. Then recently one puncture (tyre well worn down) half way to work, so new tube put in.
Can't remember anything more serious in the last few years except a jockey wheel falling out and getting lost along with its bolt. Thankfully within 1/2 mile of a bike shop that salvaged bits from a dead mech and wouldn't take a penny for them. Cool.
Posted : 28/11/2012 11:48 pm
I ride a fixed wheel road bike. What's a mechanical? The transmission is essentially maintenance free and lasts 1000's of miles.
I have fixed a couple of punctures this year, none recently, and had a spoke replaced and the wheel retensioned by a shop.
Posted : 29/11/2012 12:31 am
Mostly worn pads and things seizing up as it does not get cleaned very often
No punctures since Useing specialized armadillo tyres
Posted : 29/11/2012 9:37 am
Tired
I was the same until the day
Ping ping ping
The chainring teeth broke off ๐Ÿ˜ฎ
To be fair they were well worn - and the ring had been turned
Id had my moneys worth ๐Ÿ™‚
Posted : 29/11/2012 9:41 am
Mostly just punctures. If on nearer to home I swap the tube, If nearer to work I get someone to come and pick me up.
Posted : 29/11/2012 9:49 am
punctures - i've got puncture resistant tyres (marathons), but they've been cut up all the broken glass, and now bit of glass/sharp flint are finding their way through old slashes in the tyre.
i'm getting a puncture every couple of weeks.
brake pads coming to the end of their life mid ride - this is my fault, i knew it was worn down, but ignored 'till the weekend'...
er, that's it.
i fix it all myself.
i'd gladly swap biking for driving - if i could afford the car + insurance + petrol..
Posted : 29/11/2012 10:14 am
I have only ever had punctures while commuting and generally that's all I remember seeing other commuters having issues with. I repair all my own mechanicals.
I stopped to help a guy once and he clearly had a broken free hub. He had no idea what that meant, but when I told he was walking the rest of the way his face dropped. ๐Ÿ˜
 will
Actual mechanicals - Mainly punctures.
Gears slipping, bolts becoming loose, brake pads wearing out are all just signs of use.
Posted : 29/11/2012 10:21 am
same here, couple of punctures so went for armoured tyres which helped. now changed jobs and commute mostly offraod using Schwalbe Land Cruisers which are great. CX bike. The only time I've not fixed it roadside was when the linkage was worn on the Vee brakes and on braking the metal went into the tyre, ripped tyre. As it was after 6, no bike shops open so walked to the train station and picked up.
One thing that annoys me, is that on the occasions I've been doing mechanical repairs at side of road no other passing cyclists ask if I need a hand... bloody londoners ๐Ÿ˜‰ So now if I see anybody fixing I'll always ask if they need anything.
Posted : 29/11/2012 10:33 am
I've had many punctures, mainly repaired myself although I have sometimes run for a lift.
The worst I had was a broken freehub. I tried to fix with zip ties to make it fixed and that lasted for about 100meters. So I ended up having to run about 6 miles to work! I've also snapped a chain, luckily I had just arrived at work. I knew it was on it's last legs, but the chain was so badly snapped that there was no fixing it! Train home.
My derailleur as also seized, although you can get along without gears. And cables seizing up in the cold as well.
I've stopped and helped a lot with the same problems. So I think they must be fairly common.
Posted : 29/11/2012 10:41 am
i tend to try and fix as much myself when it goes wrong but either i've run over a black cat or walked under a ladder recently as everything seems to be going wrong...
riding into work several weeks ago my rear mech decided to give up the ghost in spectacular fashion...it snapped in half, wrapping the chain round the cassette and snapping a spoke and bending the mech hanger. i managed to remove the broken bits at the roadside and managed to sort of convert it to singlespeed of sorts and rode very gingerly into work. back wheel was also buckled, but obviously the chain is never going to be the correct length for singlespeed duties like this and the chain eventually jumped up the block where it snapped. i managed to put the chain back together for it to only happen again, but by this time i was near the office so i managed to walk the remaining half mile.
managed to get most of this repaired at the LBS.
now i've added semi slick tyres to the bike i've had loads of punctures but thankfully they've near the house so i've been able to repair them at home..but i'd like to catch the knob who keeps breaking glass on the road.
at llandegla a fortnight ago i managed to snap a bolt on the seatpost after 2 miles on the black run...tried zip ties to secure the saddle but this lasted another half mile before they snapped and the saddle fell off so i had to complete the rest of the route with the saddle and post stuffed in the camelbak :(....got some funny looks that weekend off other riders...i've managed to source the parts i need to repair the post from the manufacturers in canada so all i have to do is order them... ๐Ÿ˜€
and now i've managed to round off one of the bolts at the bottom of the fork lowers that secure the 20mm axle and need to find a replacement bolt...another trip to the LBS beckons this weekend... ๐Ÿ˜ก
Posted : 29/11/2012 10:44 am
Just puncture here. (Fixed myself obv)
I use Conti City Contact which are tough and impervious to most trail debris - but I ran right over a broken bottle in the dark and got a huge shard of glass right through the tyre.
Other than that, none really. Gears can get a bit vague with age and gunk but I run gripshift so it is easy to trim the front mech to compensate.
Posted : 29/11/2012 11:01 am
Punctures, that's about it really. Maybe once a week a mudguard might slip slightly and needtweaking, in a month a rack or guard mounting bolt will loosen, in a year a cable might snap?
The annoying thing is my commuter always takes ages to fix when it comes to peventative maintenance as it's all old kit i've no longer got tools for (1" threaded headset spanners, tapered BB's, 6 speed freewheels, etc)
I take the same toolkit as evey other ride though rarely need to use it.
Never been to a bike shop with it.
Posted : 29/11/2012 11:02 am
I've seen quite a few other commuters with punctures too. I always stop and ask if they need help. Surprising the number of people that don't carry a pump or patches - or worse, do but don't have the vaguest clue how to use them! ๐Ÿ˜•
Used to commute with a pump, park patch kit, tyre levers and allen keys. But these days, running better tyres, i just have the allen keys incase i need to adjust anything, stop a creaking seat etc...
That said, i do keep on top of my maintenance, clean the bike, chain, gear adjustment if needed at the weekend (if required). It's very easy to tell if your bike needs lube, gears are out etc... when you ride it every day.
It's not uncommon for me to lend a hand fixing other commuters bikes on route (used to work in bike shop so confident and safe to do so). The most common problem being a slipped chain, often due to the terrible condition or set up of their bike. Most people in these situations are not dyed in the wool cyclists BTW. Seen a fair few forks the wrong way round, wonky wheels, disconnected brakes, wobbly cranks and massive vs small bikes for the people ridding them. It's pretty easy to spot someone who wants help and i like to think it helps strengthen the bond within our growing cycling community.
Posted : 29/11/2012 11:13 am
Like most people here I'm pretty fortunate with my maintenance. Went through a spell of breaking chains on my last bike but since building my hack/commuter I've been pretty fortunate. That being said, I've just serviced her and put the winter tyres on and noticed a bust spoke on the back. Looks like a trip to my LBS is on the cards
Posted : 03/12/2012 12:11 am
