CO2 pumps - how to ...
[Closed] CO2 pumps - how to stop you hands from freezing?
[#1114642]
I know you can get neoprene covers for the bottles but anyone use a cheap alternative or even, dare I say it, free/home made kit apart from gloves (in the cold and wet I wanna keep my cloves on but doing tyres is difficult with gloves on 😉 ) for these little canisters:
Posted : 09/12/2009 12:33 pm
Gaffer tape.
Posted : 09/12/2009 12:35 pm
cut a finger off an old pair of gloves
Posted : 09/12/2009 12:37 pm
you can get foam sleeves to fit them.
please read my OP 😉
Gaffer tape.
Not bad - keep em comming. I dont have any really knacked old glove unfortunately but great idea 🙂
Posted : 09/12/2009 12:38 pm
Pull your sleeve down a bit over your hand?
Wrap the glove you don't want to wear whilst doing tyres around it?
How complicated do you want to make it? Really - how difficult?
Posted : 09/12/2009 12:39 pm
Blimey its only a question to a little problem - chill out!
Posted : 09/12/2009 12:40 pm
2 inch section of foam pipe lagging does the job but is relatively bulky (but light).
I just use a bit of cloth to wrap the cannisters in my bag with a rubber band around it to hold them in place and then use the cloth to hold them if I need to use them
I got a bulk box of Giant branded CO2 bottles that have the foam bit stuck on the bottle already.
Posted : 09/12/2009 12:41 pm
what too tall said
it's hardly complicated 😯
i always keep my gloves on to change tyres, you get filthy hands otherwise and we can't have that now can we
Posted : 09/12/2009 12:42 pm
I was just asking how others stopped their hands from sticking to the canisters - thats all 🙄 .The typical STW minority replies keep on comming "it's hardly complicated ". Thanks for that statement I didn't realise it was not complicated - sheesh!
Thanks to all with sensilbe replies 😉
Posted : 09/12/2009 12:49 pm
 cp
i just keep my gloves on.
BTW I was out the ohter night and my tyre blew out and I had my big waterproof winter gloves on, and changing a tight road tyre in the peeing rain and in the dark. Hence my OP 😉
Posted : 09/12/2009 12:52 pm
ooooh i'm in a minority 🙂
does that mean the Daily Mail hates me now?
Posted : 09/12/2009 12:54 pm
 devs
You could pick some daisies and make them into a few chains and then knit a cannister cover. Alternatively you could use a bit of common dog, finding something to go between your hand and the cannister isn't exactly the hardest thing to do is it? I've got a foam one and a plastic mesh thing that came with the inflators.
Posted : 09/12/2009 12:55 pm
inner tube and gaffer tape
Do everything else with gloves off, then put them back on for the final act?
Failing that, how about making tubes of rolled up corrugated cardboard - if it's good enough to stop thermo-nuclear coffee melting your skin it'll do a similar job when the temp is cryogenic. May have to experiment with how much to use.
NB: - cardboard may not play nicely with the rain scenario you mention.....
Posted : 09/12/2009 12:59 pm
[sensible hat on]
something insulating like an old sock, maybe a hiking one
inner tubes are no good as rubber is a crap thermal insulator
gaffer tape will likely start to wear as it rattles around in your bag and will turn sticky, it also behaves poorly when wet/cold which are the two things that cannisters become when you use them
Ta for the replies 😉 Its not a biggy just was interested if anyone had come up with something free (as I am a tight wad) and ingenious 🙂
Edit: Ahh - what about the padded envelopes - the ones containing bubble wrap coated in paper - then gaffer tape around the outside - cool 🙂 Cheers for the insipration Bristolbiker 🙂
Posted : 09/12/2009 1:01 pm
How about an old knobbly tyre?
Cut a strip to size & cable tie it to the canister. If you do it knobbles facing in, then the small gap this will create, should stop the cold getting to the main bulk of the rubber you are holding.
Posted : 09/12/2009 1:48 pm
yeh not bad idea stumpy - if I can find one - had a chuck out a while ago 😉
Posted : 09/12/2009 1:56 pm
 br
stay in the kitchen, its warm and uncomplicated
Posted : 09/12/2009 2:27 pm
Ta for the replies Its not a biggy just was interested if anyone had come up with something free (as I am a tight wad) and ingenious
This seems a bit odd. If you're tight (I am!) then why use CO2 in the first place? A pump is cheaper, and more reliable!
Posted : 09/12/2009 2:59 pm
An old grip?
Posted : 09/12/2009 4:15 pm
 juan
Can you warp space into a universe with different laws of physics?
Posted : 09/12/2009 4:20 pm
A 50mm section of road inner tube fits nicely over a 16g cartridge. Not highly insulating but takes the sting off and is cheap,light and not bulky.
Failing that use a ribbed condom!
Posted : 09/12/2009 4:40 pm
Coz I don't mind paying for something I can't make but am a tight wad to pay for a piece of rubber or plastic for a £1 and pay £4 postage for something I can make for free. Point made?
Posted : 09/12/2009 4:57 pm
