Anyone done this?
I have Velocity A23 disc rims with yellow tape and some Racing Ralph performance tyres.
They seem to lock in place when used with tubes but I can't get them to seal with a track pump...
So, anyone tried the CO2 method before I try to make a ghetto inflator?
(I have stans/schwalbe combo on my MTBs and they go up like a dream)
Done it on road tubeless and it worked fine. Never tried on mtb
ghetto inflator
โ An inflator of 'ghetto' combination of tyre/rim or are you making your own inflator?
I've done this a number of times - works fine. track pump just can't deliver the volume of air required - a co2 works fine if your don't have a compressor available.
I'd just make a ghetto inflator if I were you on the basis if the CO2 canister doesn't work, you've just wasted it and also once you've made up a ghetto inflator you can use it time and time again at no cost
Yes, I've inflated dozens of tyres this way. Works a treat!! ๐
* including racing ralphs, but not velocity rims. I've always gone with Stan's advice though- any mtb tyre can be used tubeless on any mtb rim, just as long as you use the right rim strip etc..
I quite often do it this way (i bought a job lot of CO2 cartridges, works out at naff all a cartridge)... despite being the OP of this http://singletrackworld.com/forum/topic/ghetto-tubeless-inflator-total-cost-9p
I've failed with 25g CO2 cannisters where the ghetto-compressor has worked fine.
Yes, bought a large box of 12oz bottles instead of 16oz. Seated CX Pro wire beaded 26" tyres onto Stans Crests without any problem.
Cheers guys - forgot to say they are 35mm CX RRs, but hopefully that doesn't make a difference. Just not wanting to deal with a puncture on the Gravel Dash if I can help it...
