Just realised the three lighter red plastic things look a lot like Shimano bleed blocks but are far too narrow. Spacers from packaging?
The bottom are disk pad spacers for various models. Often used when in transit.
Top are bleed kit parts, probably sram/reverb/avid.
Lower ones are for spacing pads in transit
So a pre-2012 XT brake block or pad fits neatly into the indent on the left most plastic whatsit. I suspect post-2012 will fit in the top/bottom ones. That's interesting but I've still no idea what they're for!
Top pic shows Reverb bleed connectors
So I turned my eyes on and noticed that the dark red thingy has Avid PS-H05 written on. Avid pad spacer. Clearly it's been a *long* time since I changed the pads on the wife's bike.
Aha, Reverb bits. Thanks!
top bits fit avid and formula brakes too. and rockshox x-loc hydraulic lockout which is a bit like a reverb button iirc. NB brakes and reverb/x-loc use rather different fluids iirc so best not to use same for both different systems unless you are sure they are properly cleaned out and dried.
Assuming you have the syringes they are worth keeping as EPic do different fittings for other brakes - eg SHimano Tektro etc
the bottom bits fit in your brakes when transporting to stop accidental lever presses from squeezing your pads in which will then self adjust and you won't be able to refit your wheels without a faff of opening out the pads again. I always keep a set in my camelbak in case the bike ever needs to be transported with the wheels off
Top bit as above is a sram bleed kit for Reverb etc. Orange fittings are luer lock syringe fittings instead of push fit type that pop off when you apply any serious pressure.
Andyl: oh, I see, yeah that's useful. I might dig around the bin for the ones I threw away!
The top ones are for injecting crack.. No wonder you have amnesia..
Marzocchi adaptors
Space Invaders (bottom pic) and the guns you shoot 'em with (top).
