Cleaning up "n...
[Closed] Cleaning up "new to me" carbon cranks
Just got some used X0 DH carbon cranks, the original heli tape is just worn through in a spot so I've pulled it off to replace, is it OK to use surgical spirit to clean up the adhesive residue?
Posted : 05/02/2013 10:28 pm
Yes, will be fine. Nothing you have in the household will attack it, used as a cleaner.
Probably find isopropanol wont be that effective on the adhesive though, use lighter fluid or something. Might remove the printed graphics though.
Posted : 05/02/2013 10:40 pm
 Sam
You'll need something more potent than alcohol to clean the sticky stuff off. Acetone will do the trick. If the surface looks a little dulled afterwards hit it with some t-cut then wax polish and will bring em up like new. Moderately deep scratches can be taken out with some fine wet & dry (800 or so) then polished.
Posted : 05/02/2013 10:58 pm
Have been known to use the black color magic back to black car polish on carbon.
Fills the small cracks with black pigment rather than white that you get with T-Cut and white car polish.
Wont leave little white dull patches.
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_219210_langId_-1_categoryId_165527
Posted : 05/02/2013 11:10 pm
thanks. I figure a bit of cleaning and polishing, new heli tape and some crank boots and they'll look pretty good again.
Posted : 06/02/2013 1:32 pm
Buy a bottle of sticky stuff remover - amazing at removing glue residue, tar spots, etc
http://www.lakeland.co.uk/8976/Sticky-Stuff-Remover?src=gfeed&gclid=CJ6eq8fbobUCFYLHtAodanMA3A
Posted : 06/02/2013 1:47 pm
GT85 is good for removing sticky stuff
Posted : 06/02/2013 2:10 pm
Not really IMO, white spirit or nail varnish remover are vastly more effective if you want something you're likely to have around.
Posted : 06/02/2013 2:12 pm
If they are scratched, rub them down lightly with some fine wet & dry then give them a coat of clear lacquer from a rattle can. I have restored scratched black plastic road brake hoods in this way, they looked like new plastic.
Posted : 06/02/2013 3:03 pm
