Having a little problem with my clarks hydraulic brakes. I can't seem to push the pistons back to the original position. I've tried using a screwdriver to lever them back with no luck. They also look slightly wonky. Any advice on what I could do?
Posted : 14/09/2011 8:29 pm
let some fluid out, sounds like they might be overfilled
Posted : 14/09/2011 8:31 pm
thanks, what's the easiest way to do that?
Posted : 14/09/2011 8:33 pm
If they look wonky, then you've probably got them cocked in the bore. If you can get a screwdriver right the way through the caliper body, you can apply pressure on both edges of the piston, and hopefully winkle it back into it's correct position, they're a snug fit and need to be pushed in straight otherwise they'll jam like yours.
Posted : 15/09/2011 8:05 am
Cheers, will give that a go and let you know how I get on.
Posted : 15/09/2011 9:02 am
