As title suggests,
have a CK heavy Duty Front hub and want to convert to 9mm QR or bolt on
Anyone managed this and any ideas if where one can be procured in the UK
Iirc you can't. Assuming you have a 20mm hub.
Oh dear this ain't heading in the right direction
15mm currently on
tom is right, the 20mm hub only adapts down to 15mm.
Towhoward is correct...it's only the SD hub that can be setup for a 9mm QR (or 15mm). I bought the larger diameter so that I could use 15mm or 20mm, knowing I'd never use a standard QR again.
Cheers guys. Just need to decide what to do.
Clutching at straws but there's nothing aftermarket is there
shirley........if you purchased a bolt thru only hub, you already know that a qr will kill you...no?
We all don't live on a perfect world
As it happens I've had these hubs kicking around for
some time. So any assumptions are unfounded
