Chris king driveshe...
[Closed] Chris king driveshells
[#5054821]
Should I be able to pull my driveshell out of the hub body ever so slightly when the axle isn't fitted?
Posted : 10/04/2013 9:46 pm
Yes. In fact, you can pull it all of the way out once the axle is removed. Twist it anti-clockwise as you pull the driveshell.
Posted : 10/04/2013 9:57 pm
Thanks but I know that, that's how I serviced it. The 'play' is what I'm concerned about.
I'm going to assume however that you've got good grammar and are not prone to inserting full-stops willynilly, in which case, thank you good sir/madam, I shall now fit the axle and ride off into the sunset metaphorically.
Posted : 10/04/2013 10:03 pm
Ke?...
Posted : 10/04/2013 10:48 pm
