Cheapest IT solutio...
[Closed] Cheapest IT solution to run Zwift?
8 Users
I've been reading the Zwift thread and I want to join in. However my PC is still running XP. I don't really have an other use for a laptop or PC so how cheaply can I cobble something together just to be a Zwift/turbo trainer computer.
(PS Mr TW is a software engineer and can build from parts)
Posted : 23/11/2016 8:39 pm
If you have an iPad the app will be out soon.
Posted : 23/11/2016 10:03 pm
No Ipad. I wonder if buying one may be the cheapest option?
Posted : 23/11/2016 11:17 pm
I've run it well enough on a basic laptop £2/300 but you should be able to put together a desktop from old an new parts for less.
Then a basic turbo, speed sensor and ant+ usb are all you need.
Posted : 24/11/2016 12:54 am
If your trainer/speed/cadence/heart rate sensors are Bluetooth you don't even need a dongle for your computer, you can use your phones bluetooth via the zwift mobile link app.
If in budget I'd recommend a smart trainer (tacx flow from Halfords is £200) as it's much more fun having it change resistance for you.
Posted : 24/11/2016 6:50 am
computer-wise, cheapest prob to buy W7 and maybe a slightly posher video card if needed ? (if your pc can run 64bit). Then a ANT+ dongle for 10-20 quid
bike-wise. do you already have a turbo trainer that's on their list of compatible devices? Mine's pretty old but it's on there and works fine as a dumb device. If so, then all you need is a speed sensor (can have cadence & HR too but I think it'll run without)
Posted : 24/11/2016 10:26 am
In the same boat as the OP. Just picked an iPad mini 2 up from Tesco. £189 but I had another £24 in club card vouchers to use so picked up for £165. Will be good for general stuff and for the kids too so seemed like a good option.
http://www.tesco.com/direct/ipad-mini-2-32gb-wifi-space-grey/380-0143.prd?skuId=380-0143
Posted : 25/11/2016 7:56 pm
Hi can anyone tell me if they think this will be ok for zwift https://www.amazon.co.uk/enabled-Dell-Optiplex-Certified-Refurbished/dp/B01H5OFUIK/ref=cm_cr_arp_d_product_top?ie=UTF8
Posted : 27/11/2016 7:39 am
thats what i run apart from mine has 8gig ram
i had to buy a graphics card as the built in one is rubbish
Posted : 27/11/2016 7:48 am
Posted : 27/11/2016 7:58 am
If I was building one from scratch, I would probably try and get a refurbed desktop to have permanently set-up with the turbo trainer and pair it with the largest monitor I could afford. Probably a cheap pair of speakers too.
I was surprised my almost 6yr old mid-range (£550) laptop runs it without issue even though the graphics spec is below the min spec required by Zwift.
Posted : 27/11/2016 2:44 pm
