Charger damper conf...
Charger damper confusion 🤷
The top cap says "charger"
Trailheads says "n/a"
Without taking apart, am I missing anything in identifying the damper??
Top cap
Trailheads
Posted : 13/06/2023 11:36 am
It's a Charger RC, but all it seems to have in relation to other Chargers is the name. Apparently quite different and more basic inside
Posted : 13/06/2023 11:48 am
Where did you find that info?
Posted : 13/06/2023 11:52 am
So it has a c1 airspring but a poor damper from looking at the info on trailheads?
Posted : 13/06/2023 11:58 am
Isn’t the charger rc damper some kind of ifp sealed against the inside of the stanchions - rather than a bladder damper like higher spec forks of the same year?
Maybe it’s the same damper as the OEM only Revelation / Yari Charger RC?
Posted : 13/06/2023 12:07 pm
This shows the differences
Posted : 13/06/2023 12:14 pm
Try page 27 of the following guide - might be one of these. Looks like it is a cartridge but with an ifp setup rather than the bladder full charger damper. Perhaps it’s similar to the basic Fox grip damper. Should be better than moco.
Posted : 13/06/2023 12:15 pm
I had a Lyrik RC a few years ago.
It was pretty decent. Only noticed the damping was better when I got an Ultimate, rather than noticing any issues when I had it.
Posted : 13/06/2023 12:20 pm
Cheers all, ordering a c1 air spring and charger 2.1 rct3 damper for it I think
Posted : 13/06/2023 12:21 pm
Should now be this spec
Posted : 13/06/2023 12:53 pm
My guess would be it has a charger bladder style damper but with only low speed adjust and the oldest debonair air spring.
If so I had the same fork  changed the air spring for the C2 (I think? Not the newest but the one before) as that really improves the spring side but it was a decent fork
You could just take the tops off and check.
Posted : 13/06/2023 1:23 pm
Posted : 13/06/2023 1:26 pm
Thats a Charger2 RC bladder damper, not the IFP based one.
Posted : 13/06/2023 1:52 pm
That's the one I was talking about (as serviced by you I think Rick).
Main (only?) benefit of the Ultimate was being able to dial the HSC down.
If you like a bit of HSC anyway, it might suit you fine OP.
Posted : 13/06/2023 2:15 pm
Cheers @rickdraper
Posted : 13/06/2023 2:37 pm
Fork whipped apart and as @rickdraper said
Charger damper with rebound and lsc
And 170mm air spring
Both now going spare of anyone wants them!
This is the fork in question - page 20!
This is it
Posted : 14/06/2023 9:53 am
Well that was a night and day upgrade success!
The new C1 air spring coupled with the Charger 2.1 RCT3 damper - last nights ride on teh same route as usual, crazy smooth, supportive, no dive, no arm pump! The airspring i'm sure had a lot to do with it.
Put the settings in that Trailhead gave me, popped a shockwiz on for curiosity, came back all good!
Posted : 15/06/2023 12:40 pm
joebristol reacted
