Changing rotors, do...
[Closed] Changing rotors, do I need to re bed in the brakes?
[#3965755]
Erm, well, do I?
Posted : 11/05/2012 4:18 pm
Didn't need to when I changed mine......I daresay you might have to if they are brand new rotors though
Posted : 11/05/2012 4:21 pm
You would be well advised to perhaps clean the pads with IPA and possibly sand with some 800 sandpaper. Then find a nice steep hill and do 4 or 5 hard stops to conform the pad to the rotor. Oh also, clean the rotor with IPA to make sure there is no protective oil on it.
Posted : 11/05/2012 4:40 pm
Don't use surgical spirits to clean pads...I did and had to buy new pads!
Posted : 11/05/2012 5:24 pm
 MSP
No, bedding in is about heat cycling the pads and compressing them while doing so.
Some people claim its about getting pad material on the rotors, I think that's nonsense.
Posted : 11/05/2012 5:47 pm
MSP its a scientific fact. Its about leaving a fine layer of pad on the surface rotor.
You also need to fit the pad to the surface of the rotor.
Posted : 11/05/2012 6:08 pm
No. Just ride. It'll be alright.
Posted : 11/05/2012 6:13 pm
 MSP
Well that's convinced me!
Posted : 11/05/2012 6:35 pm
it'll be OK - go and ride
Posted : 11/05/2012 7:21 pm
The advice about giving the rotor a good scrubbing is the best thing - use IPA or meths. I would try to bed them in a bit as well as the theory is you 'key' the pads to the rotor by leaving a small amount of pad on the rotor.
I find pads incredibly inconsistent. My current pads have lasted ages - loads of mud, winter rides in the Peaks etc. I did take the trouble to burn them in quite well, though.
However, I think my second longest running set were just bedded in while riding normally - some that I have bedded in have disappeared in no time!
Posted : 11/05/2012 7:41 pm
