Changing hub adapto...
[Closed] Changing hub adaptor on superstar switch hubs- easy?
Been sent the wrong hub. Been offered the right adaptor but worried I will mess it up.
Anyone done it and how hard is it?
Ta
Posted : 19/01/2015 10:34 pm
Absolute piece of cake to change, 2 min job iirc (on both front and rears)
Posted : 19/01/2015 10:47 pm
 cp
Front and rears both very very easy.
Posted : 19/01/2015 10:49 pm
Many tools needed?
Posted : 19/01/2015 11:02 pm
none - should just pull out and new ones push in
Posted : 19/01/2015 11:09 pm
You can pretty much get away with using two strong fingers
 cp
rears are easier with two 17mm spanners/lock nut spanners.
Posted : 19/01/2015 11:25 pm
Minor hijack, but if it's easy to swap the adaptor, is it worth swapping the rear QR for 10mm bolt through.
Posted : 19/01/2015 11:34 pm
mcnultycop I've got a ti 29er - really helps stiffen the rear end of that. But if your frame's already stiff it won't make as much difference
Posted : 19/01/2015 11:42 pm
