changing from tripl...
[Closed] changing from triple to double chainring set up - advice please
I currently run a triple chainring. I'm thinking of removing the big chainring and just running a double with a bash guard.
Do I simply need to adjust the limiter screw on my existing front mech set up to stop it trying to move in to the non-existant third ring?
Is there anything else I need to change or do to the front mech or shifter?
thanks
Posted : 18/06/2009 6:54 pm
You got it spot on. Simple really.
Posted : 18/06/2009 6:57 pm
thanks Chase. It seemed logical but a bit too simple!
Posted : 18/06/2009 6:59 pm
 AB
[url= http://www.singletrackworld.com/forum/topic/fs-e-thirteen-supercharger-bash-ring-4-bolt-black-36t-910-condition-2 ]Could you be doing with this?[/url] ๐Ÿ˜‰
Posted : 18/06/2009 7:13 pm
AB - what an opportunist!
Thanks, just thinking about it at the moment. My middle ring is 32t so maybe I'd need a 32t guard?
Posted : 18/06/2009 7:23 pm
never adjusted nowt, just don't try and shift up to third. Easy really.
Posted : 18/06/2009 9:50 pm
 Epic
I'm running a 22t/36t/FSA '36't bashring set up and it's spot on. Gives me a good gear range with some nice top end speed for the downhills.
When I previously ran a 22/32 setup I was spinning out on the descents and getting left behind ๐Ÿ™
Posted : 18/06/2009 10:24 pm
 juan
nothing to chance. Just don't shift to big ring
Posted : 18/06/2009 10:31 pm
 jonb
I didn't adjust anything, just avoid shifting up the second time.
Man up & go 1x9.
Go on.
Dare ya...
Out of interest, & primarily because I'm a thick dozy wazzak etc, why do people usually go with a bash guard when they go to a double set-up ?
Can you not just ditch the big ring & use shorter bolts...?
Am I missing something ?
Posted : 18/06/2009 10:42 pm
Don't bother adjusting the front deraileur, you won't be able to change up anyway.
Posted : 18/06/2009 10:55 pm
takisawa2, I'm going from a triple to a double specifically so I can fit a bash guard to stop the the chainring gashing the back of my leg. I hardly use the big ring so it's no loss. I will probably change middle ring to 36t.
Posted : 18/06/2009 11:15 pm
 juan
I got to 2+bash because I rarely used the big ring expect to get stuck on rocks...
So the bash guard is protecting the middle ring now.
Posted : 19/06/2009 7:58 am
