Changing Fork offse...
Changing Fork offset
So I have a Trek pro-caliber with some 100mm RockShox Recon on it with a 42mm Offset.
Merlin have these at a bargain price: https://www.merlincycles.com/fox-32-rhythm-float-grip-boost-mtb-forks-29-280579.html
However offset is the more standard 51mm.......
Will it ruin the handling?  Is my frame specifically set up for the shorter offset? I can't believe it is.....
Posted : 16/07/2024 1:15 pm
 5lab
frames can't be set up for one or the other, but offset interacts with wheel size and head angle to provide a certain feel. it'll marignally improve handling at higher speeds and marginally worsen handling at lower speeds
Posted : 16/07/2024 1:26 pm
Your new fork will move the axle 9mm further forward so 9mm longer wheel base but weight distribution will shift slightly backwards. I doubt it will make much difference on a XC bike.
Posted : 16/07/2024 1:33 pm
it’ll marignally improve handling at higher speeds and marginally worsen handling at lower speeds
How does longer offset, which is to say shorter trail, make that so? I think it is opposite, in theory.
Posted : 16/07/2024 2:08 pm
Not mtb but my gravel bike has flip chip in front forks to adjust offset by 5mm.
I have longer, open gravel routes near me as opposed to tight, twisty stuff so run the fork in longer Offset mode. It's barely perceptible but the bike does feel slightly more stable at high speeds compared to the reduced Offset setting. There really isn't much in it though.
Posted : 16/07/2024 2:24 pm
 5lab
ah you're right i got things backwards
Posted : 16/07/2024 2:55 pm
Erm I'm confusedederer now - a longer offset gives a shorter trail?  I thought a longer offset would give a longer wheelbase? Or is trail different to wheelbase?
Posted : 16/07/2024 3:51 pm
https://bikeinsights.com/cyclopedia/trail
Posted : 16/07/2024 4:06 pm
I put that exact fork on my Xcaliber which came with a 42mm offset fork. It made the handling rather twitchy, as the increase in offset reduces the trail so much it feels like a 1.5 degree steeping of the head angle (according to this link https://www.fanatikbike.com/blogs/engage/who-the-heck-cares-about-fork-offset-and-what-the-heck-is-trail).
Great fun when using the bike on easier trails and if you are using the caliber for more gravel oriented stuff, but it exacerbates the already steep head angle compared to modern XC MTBs.
Posted : 16/07/2024 4:25 pm
Yeah well in that case I'll pass - thanks that's really useful. I already feel its a bit twitchy.
Posted : 16/07/2024 5:57 pm
You probably won’t notice the difference.
Posted : 16/07/2024 9:35 pm
