Chainring offset. H...
Chainring offset. Help!
Right, I need some help with chainring offsets please.
Want to put a shorter crank on my new Cotic Rocket Max, Cotic states:
Chainline: 52mm Shimano / 53mm Boost chainline for up to 32t round/30t oval chainring,
I've seen a crankset that is either 50 or 53mm chainline and takes a Sram 3 bolt chainring, which most seem to be 3mm or 6mm offset.
From what I've read offset is inboard, so if I put a 3mm offset chainring on the crank set with 53mm chainline does that end up as 50mm and therefore NOT compatible with my bike?
Or can I put one on the 50mm CL crank backwards and get 53mm....
Posted : 14/05/2025 7:48 pm
Typically, Shimano control offset with axle length.
Typically others have a standard crank and control offset with the ring. It's likely that the 53mm is a 3mm offset ring and the 50mm is a 6mm off set ring, both starting from the same place. However, SRAM can be a minefield and it can vary by bottom bracket type
Posted : 14/05/2025 8:08 pm
Posted : 14/05/2025 8:25 pm
 mboy
What Onzadog says…
Though it always used to be that a 6mm offset ring gave 49mm chainline, a 3mm gave 52mm and a flat ring 55mm with SRAM… That is until they buggered around further outboard with the latest T-Type stuff chainline wise.
Shimano have typically changed the offset with a longer axle as previously stated, so you need to change cranks with Shimano to change the offset, but only need to change chainring with SRAM to change it…
Posted : 14/05/2025 8:36 pm
Ah so if I bought the 53mm CL crankset and swapped the 32 tooth chainring it comes with for a 3mm offset 30 tooth it would remain a 53mm CL and be bang on the CL Cotic recommends?
Cool, think I get it now. Basically I don't want to spend a fortune at the moment and buy Hope 155 cranks, but have found some Cube own brand ones that come in 160mm for not much money, so fancy giving them a try for a while and see I get on.
Cheers both.
Posted : 14/05/2025 8:39 pm
Very likely but the reason for liberal use of the term "typically" is because not everyone plays by the rules, sometimes not even their own rules
Posted : 14/05/2025 8:42 pm
Cool, makes sense though so I might give it a go. Cranks are only £60.
Posted : 14/05/2025 8:48 pm
