chainlube, that cam...
[Closed] chainlube, that came solid in a tin, and you heated it up on a camping stove??
 ton
can anyone remember it?
please
and thanks.... ๐Ÿ˜€
Posted : 20/05/2014 3:09 pm
Might not be the same one you're thinking of, loads of motorbike lubes were like that- I use putoline, brilliant stuff, best chainlube I've used by miles (but epic, epic faff)
Posted : 20/05/2014 3:13 pm
putoline +1
Best stuff by far, apparently even better if you can get hold of an old chip fryer to keep in the shed.
Posted : 20/05/2014 3:19 pm
make your own, from ebay get some pelleted paraffin wax (without stearin) and graphite powder. Think the ratio I used was 25% graphite powder. Don't do it in the kitchen ever under any circumstances ever!
Posted : 20/05/2014 3:25 pm
Grounds for divorce? ๐Ÿ™‚
Posted : 20/05/2014 3:32 pm
 scud
There was an article on one of the roadie sites or mags (one of the last few Cycling Weekly?) saying that Team Sky are currently experimenting with one of the solid lubes at present that has to be melted first, you'd probably find something if you searched for that?
Posted : 20/05/2014 4:14 pm
I tried that route with some grease I'd acquired. It wasn't until late in the proceedings that I realised it was high melting point grease. It was not a success.
Posted : 20/05/2014 4:31 pm
You don't want grease though because it's sticky, wax and graphite and/or teflon powder is pretty much the same (I think) as the putolin stuff
Posted : 20/05/2014 7:07 pm
I think I read that muc-off are working on a heat up wax, and they are now the pink stuff provider for team sky aren't they? So I suppose its not far fetched to imagine that sky are experimenting with it.
Posted : 20/05/2014 7:16 pm
Good stuff, I use putolene in the winter and squirt in the summer.
Posted : 20/05/2014 7:17 pm
That wax was great on the motorbikes. It works best when done on the kitchen cooker when your mum is out.
Posted : 20/05/2014 8:04 pm
 br
[i]That wax was great on the motorbikes. It works best when done on the kitchen cooker when your mum is out. [/i]
Use to be used before we had O ring chains.
And what you shouldn't do is drop the tin after it's been in the oven and all liquid... and then I burnt my fingers picking up the red-hot RD250E chain. ๐Ÿ˜ณ
Posted : 20/05/2014 8:35 pm
 StuE
Think it was called Linklife
Posted : 20/05/2014 8:42 pm
b r - Member
I think I'd move house. Every time I do it I half expect to burn down the garage.
Posted : 20/05/2014 10:25 pm
