Chainguide system h...
[Closed] Chainguide system help
Hi,
I Have decided that when head out to Morzine this summer I want to use a chain guide system to keep my chain on the chainrings as this weekend in the peaks I had the chain off boths sides of the chainrings at some point...
Frame: Specialized Enduro S-Works 05 with ISCG mount. 73mm bb width.
Chainset: Shimano XT 2012 2x10 (26/38t)
I have no idea what im doing when it comes to chain guides as I have never looked into it.
Any help would be greatly appreciated!
Thanks
Mike
Posted : 01/04/2012 10:51 pm
Do you have a bashguard? You'll probably want one for the Alps. Easiest setup would be a Blackspire Stinger, they come in iscg, 05 & bb mounts and loads of colour choice.
Posted : 01/04/2012 11:07 pm
I was looking at the E13 LG1+ chain guide it has a bash plate which would be handy as I don't think I can use a bash guard on my cranks (2x10)..
http://www.e13components.com/product_lg1plus.html
Posted : 01/04/2012 11:10 pm
That's only going to work with a single chainring. You'll need something like [url= http://www.sram.com/truvativ/products/truvativ-x-guide#/path/term-id/40 ]this[/url] if you want to keep 2 rings & derailleur.
Posted : 01/04/2012 11:13 pm
E13 TRS would be my choice for a 2x10. When they're available.
Posted : 02/04/2012 4:26 am
I use an E-13 DRS and a bashguard with my 2x9 and it worked quite well but still dropped a few chains on Whistlers braking bumps. The stepped roller doesn't really work that well in practice though, I always find it doesn't shift up to the inner roller section if you go to the granny ring and so it rubs more.
Posted : 02/04/2012 4:43 am
Gamut dual ring chain guide - I run one on my nomad c with 2 x9 set up. Prior to that I ran an E13 SRS+ on my 5 with 1x9 set up. Both good manufacturers but expensive.
Posted : 02/04/2012 6:09 am
