Chain suck moving f...
[Closed] Chain suck moving from granny to middle - c456
[#4747032]
Any ideas on obvious fixes? Reading around suggests c456's are plagued by it.
All components have been moved across from an old bike where chain suck was never an issue. Now I get it every ride.
Chain is almost new and certainly not stretched - granny rings looks OK and middle ring is possibly a little worn.
It's making a real mess of my carbon frame every time it sucks no matter what protection I put in it.
Posted : 13/01/2013 9:54 pm
Only way I sorted suck out the twice I had it on my steel 456 was new granny and middle rings in my case.
Posted : 13/01/2013 9:56 pm
New rings sorted mine too
Posted : 13/01/2013 9:59 pm
I pre-emptively fitted a frame guard to my c456, which of course, hasn't had any chain suck issues at all......
Posted : 13/01/2013 10:14 pm
3 of us have c456's and no issues. Replace your chain rings IMO.
Posted : 13/01/2013 10:38 pm
I had this on my C456 with new chain rings too, shortened the chain and problem was fixed.
Posted : 13/01/2013 10:50 pm
Are all chain rings made equal?
Need a 22t and 32t - unless I bight the bullet and go 2x9 instead of 3x9.
Which chain rings would you lot recomend?
Posted : 13/01/2013 11:06 pm
 DT78
not a c456, but my chain suck was cured by using steel rings. Added bonus of being cheaper too, for a slight weight penalty
Posted : 13/01/2013 11:11 pm
maxtorque - did you make that ?
Looks more like he bought it from Ann summers! 🙂
Posted : 13/01/2013 11:13 pm
Wouldn't mind one of those protectors you've got either. Where's that from?
Posted : 13/01/2013 11:25 pm
clutched rear mech, sorted, as it has mine. zero. chain suck
Posted : 14/01/2013 12:20 am
Yeah, frame protector? Where from? I like.
Posted : 14/01/2013 12:26 am
I made that CF protector, it's just sikaflexed to the frame (i took the pattern directly off my frame, so it's a good close fit)
Posted : 14/01/2013 12:37 am
Scaredy I bought one for my mojo from [url= http://stores.ebay.co.uk/Extreme-BikeSportZ/Carbon-Rock-Guards-/_i.html?_fsub=2466276011 ]this[/url] place.
Posted : 14/01/2013 1:07 am
 hora
Not happened to me but I use a chainguide if it helps(?).
Burt at On One will be along soon
Posted : 14/01/2013 7:53 am
Your chain rings and chain will be worn according to the chain line on your old bike.
Any variation to the chainline on a worn setup - such as moving it to a new bike - will increase the chance of chain suck as the wear angle isn't the same.
Hence, replace your chain rings, and ideally your chain and cassette also.
Posted : 14/01/2013 8:09 am
Kryton57 - that makes absolute sense. Thanks.
Can anyone recomend a decent make of chainring? Needing both 22t and 32t.
Thanks
Posted : 14/01/2013 9:00 am
The old steel inbred's had a bit of rep for chainsucking regardless.
I suspect that its down to drive train wear. Steel middle ring sorted it when I had issues. Its because the steel ring has narrower teeth, so theres less to grap the chain when its a bit worn.
Posted : 14/01/2013 9:36 am
 igrf
Kryton57 - Member
This
Having said that, for the first time in three winters I've been getting chain suck with my Hammerschmidt set up, but it is exacerbated by the usual causes, mud and crap and running on small cogs at the back rather than changing up at the front.
This time of year, keeping the rear mech tensioned by being in the lower rear gears is always advisable, as well as cleaning the bloody chain which of course I don't since I'm out on it every day before work and when I get back and it's cold and dark both ends of the day so the bike only gets a clean once a week if it's lucky.
Posted : 14/01/2013 9:45 am
I've only had it once or twice on my C456. Re-adjusting and aligning the front mech seems to have gotten rid of it.
Probably totally unrelated it was just the last thing ive changed on my bike and i've not had it since....
Posted : 14/01/2013 10:43 am
The front mech shouldn't have anything to do with chain suck, as it normally happens after the chain has been through the front mech.
Posted : 14/01/2013 11:38 am
Yeah,
Although now my front shifts have been made a lot, A LOT tighter and quicker, I've not had suck. Seriously my front mech is so dialled and shifts so precise.
Posted : 14/01/2013 1:16 pm
