chain stay protecto...
[Closed] chain stay protector clashing with gear cables??
I have just bought a lizard skin jumbo chain stay protector for my Genesis Core 50. The problem is the rear mech cable is routed along the chain stay - half exposed and half with an outer and a lug separating the two.
what the best way of mounting the lizard skin under/over that lot without affecting the operation of the gears or am I wasting my time?
Posted : 08/02/2011 11:33 pm
Full-length outer.
This worked for me last time I had this issue:
- Unhook the cables from the guide (shift to easiest gear then don't pedal and shift all the way to hardest to get some slack in the cable).
- Put the protector on and find out where the cable guide is underneath it.
- Cut a small hole in the protector and stick it back on with the cable guide poking through.
- Put the cable back in the guide (over the protector) and shift back to a normal gear.
You should be left with the cable running over the now protected chainstay.
HTH
Posted : 09/02/2011 12:16 am
