chain skipping prob...
[Closed] chain skipping problem - help needed!
6 Users
Hi,
i put a new cassette on in march and dont a few hundred mile since then. anyway, snapped my chain last week and put a new one on.
i fitted it at the right length and everything yet when im in the hardest gear it skips like a bugger. i really wouldnt have thought that the cassette is that worn, but something isnt matching up.
is it time for another new cassette or what?
advice is appreciated!
ta
Ben
Posted : 04/12/2009 1:24 pm
Have you got a stiff link?
Try circling the cranks backwards and see if it snags on the bottom jockey- where you joined the chain it may be a little stiff- need to use the chain tool to open the link out slightly
Posted : 04/12/2009 1:35 pm
 RicB
I would expect a chain to last more than a few hundred miles before stretching enough to wear a cassette.
You should try and borrow a chain wear indicator from someone to see how worn your old chain is/was.
Only other thing it can be is a twisted link (usually an inner link) on the new chain.
If it's not overly worn, why don't you just repair your old chain with a powerlink and carry on using it?
think it is a stiff link. the old chain was very old - 2years old i think, so when it snapped again i binned it.
i'll inspect the links tonight and see what happens
Posted : 04/12/2009 1:46 pm
2 yr old chain? worn out and worn the cassette out would be my guess
Posted : 04/12/2009 2:43 pm
 redx
Does it happen on all your chainrings? If not, I'd suspect one of your chainrings is the culprit, probably the middle one.......
Posted : 04/12/2009 2:48 pm
no, just the hardest gears on the cassette.
i think it'll be a stiff link - cassette doesnt look too worn
Posted : 04/12/2009 3:04 pm
Check your middle chainring, i'ed bet i could be that.
Posted : 04/12/2009 3:44 pm
