Chain ring clipping...
[Closed] Chain ring clipping chin stay... Solution?
[#9536908]
So... First issue with the build encountered - where's that beer.
Pinnacle Arkose SS (EBB), ultegra 6800 crank, wolth tooth oval 42T chainring and it's just a bit too close for comfort to the chain stay, it's clipping the inner tube wrapped round it for protection - any give and it will clip the frame.
I guess I have a few possible solutions going round in my head and wanted to get opinions before doing something calamitous.
1: Move the EBB shell out a few mm - seems simple & doesn't cost anything, suspect it 'might' put undue stress on 'something' due to not being centered.
2: I got the 68mm specific ultegra BB, can I drop a spacer or two in the drive side or will it then not connect with the inner plastic tube hing properly and suffer ingress of grot.
3: I'm guessing the right tool for the job is a 73mm BB with spacers, certainly looks like there is enough to play with there on the chain line.
Posted : 07/09/2017 10:38 pm
2 or 3 won't work as the crank axle won't be long enough to engage with the nds crank arm fully. No idea about 1.
Posted : 07/09/2017 10:50 pm
Balls - good point.
Posted : 07/09/2017 10:53 pm
Smaller chainring, with a bigger rear sprocket?
Posted : 07/09/2017 10:59 pm
I have a 38t that does fit but I'd be a bit gutted to drop the wolth tooth, don't think there would be an issue if it wasn't an oval ring.
Posted : 07/09/2017 11:03 pm
Mount the chainring on the outside of the spider if you havent already
If you have, add some washers behind it.
Rotate the EBB round to a more forward position
Cant see why it'd be doing this though; a 50T compact chainset works fine on an Arkose
Posted : 07/09/2017 11:04 pm
Fit an MTB crank if all else fails.
Posted : 07/09/2017 11:06 pm
How much clearance is recommended? If I take off the inner tube it will clear the frame by a baw hair - I guess it only takes the EBB to slip a fraction though and it's disaster time
Good shout David, cpl of washers should do us
Posted : 07/09/2017 11:09 pm
I thought it was odd there was so little clearance too TBH
