Centrelock rotors
[Closed] Centrelock rotors
Hi
Quick query. I'm looking to replace my front rotor (currently a Shimano 180mm, part number SM-RT54-M). It's a centrelock fitting, with external notches on the lock ring. When I look for a replacement nearly all appear to have internal notched lockrings. Are the discs the same and it's just the lockring that varies? Or is the external notch lockring a different fitting than the internal, if that makes sense? Any help appreciated!
Posted : 16/04/2016 8:14 pm
The externally notched ring, uses a BB tool to undo it, whereas the internally notched ring uses a cassette tool. Why the difference? Because if you run 15 or 20mm axles, there isn't enough space to get a tool into the "Hole" in the middle of the internal ring type, so you need to use the external notch type!
Posted : 16/04/2016 8:58 pm
So it is simply the tool required that is different, the rotor itself is the same whether it comes with an internal or external lock ring? I have the relevant BB spanner to remove/refasten...
Posted : 16/04/2016 9:04 pm
Yup, rotor is identical!
Posted : 16/04/2016 9:19 pm
