Centrelock problem ...
[Closed] Centrelock problem - Shimano rotor DT hub
DT 15mm centrelock 240 / spline1 front hub
Shimano XT centrelock rotor and internal lockring.
Ive got two cassette tools and neither of them fit over the DT 15mm adapter, the splines line up fine it just wont go on as the tool is too thick/ internal diameter too large.
Rear 142x12 has gone on fine.
Do i need to source a different tool or source one of those external lockring things?
Posted : 07/08/2018 10:51 pm
You'll need an external Lockring on any 15mm hub and then an ht2 bottom bracket tool
Posted : 07/08/2018 10:58 pm
Result, the wheels came with 6 bolt converters including an external lockring, job done.
Posted : 07/08/2018 11:01 pm
