Centralise the pads...
[Closed] Centralise the pads over the disc - The Hope Technique...
[URL= http://i237.photobucket.com/albums/ff100/capoz77/hopecentral_zps83df60df.jp g" target="_blank">http://i237.photobucket.com/albums/ff100/capoz77/hopecentral_zps83df60df.jp g"/> [/IMG][/URL]
or video
So I centered the caliper by sight evenly with the rotor, then pressed lever till first pad hit the rotor, then held the rotor firm to allow the second pad to ease out to contact the disc, as per Hopes reccomendations. It didn't work and everytime resulted in very slight skimming of rotor and uneven pad biting on the rotor.
Reverted to the method every other brake uses and spun wheel, pressed lever, then tightened caliper, perfect first time.
Just wondered if any of the Hope brake owners went down the pad centralising route with success.
Posted : 09/08/2014 10:41 am
Rotor straight?
Posted : 09/08/2014 10:42 am
Hey Mike, yeah brand new rotor and new brakes. Worked fine first time by lining up on sight only, until I started messing around by holding the rotor and trying to dial in the second pad, its not easy to put even pressure on both sides of the rotor either side of the caliper and then press the lever ๐Ÿ˜†
Just seemed a really odd technique when the spin, press, and nip up method worked so well.
Posted : 09/08/2014 10:48 am
Sticking pistons ?
Or if they are new , ignore the skimming and go ride , they wont be skimming by the end of the ride and the the pistons wil be freed off and working correctly.
Even piston movement helps avoiding sticky pistons.
Posted : 09/08/2014 10:59 am
Does seem odd compered to the spin, press and nip method. But the video does say that doesn't work! (Seems to work for most people)
Posted : 09/08/2014 11:04 am
I tried the hope method which worked but the other method is easier and works just as well ime
Posted : 09/08/2014 11:06 am
Morning trailrat, i've got them working perfectly with no skimming just by pressing the lever and nipping up.
The video states "you can't centralise a caliper correctly by loosening the bolts, pumping the lever and retighening the bolts" seems to go against the way the masses center calipers. If I try the technique in video then I get skimming.
Posted : 09/08/2014 11:08 am
Ime centralising between the pads with hopes results in mushy lever when riding.
Centralising to the calipers and letting the piston seals bed in results in a much better feeling brake imo.*
* wonders if folks bodging fitting has something to do with folks bad experiances of hope brakes being spongey and always feeling like they need bled.
Posted : 09/08/2014 11:15 am
Its important to set up the callipers so the pads are parallel with the disk and each pad the same distance from the disk. How this is achieved is irrelevant imo
Posted : 09/08/2014 11:21 am
Use a brake pad alignment tool, [url= http://www.chainreactioncycles.com/hayes-pad-rotor-alignment-tool/rp-prod35769?gclid=CJ7bwsijhsACFSHItAodew0ASQ&gclsrc=aw.ds ]such as this one[/url] or just use a couple of feeler gauges.
Posted : 09/08/2014 2:24 pm
