and on what bike ?
I read up a lot on the CCDB prior to messing with mine, seems like it favors rather high sag. I currently run ~35% sag on a 08 Turner RFX. Best shock I've ridden by a long shot. You'll need to back off that low speed compression quite a lot though.
nah - with 35% sag, you'd need to wind up the LSC and back off the HSC and adjust LSR and HSR to suit, surely ?
fwiw, i'm also at 35% sag, but suffering pedal strike somewhat 😯
Nope - I reduced the LSC to improve slow speed action over smaller bumps etc, I also reduced the LSR one click to achieve a somewhat slower return. I've actually left the HSC and HSR alone in factory settings.
35% sag causes the odd pedal strike for me as well if I don't watch out, running a 550 steel spring, weighing 90kg + gear
Performance is a huge improvement over the stock RP23, seems to work better the faster the bike goes.
awi - i hear you.....but the RFX is a 160mm frameset and the RP23 / Monarch, etc, just can't deal with mid-stoke developed by such long travel action.
my 6 Pack was transformed with the CCDB, but I ran only approx 28% sag, and it ruled 🙂
I wouldnt recommend doing things approximately with this shock. Do you mean 28% sag or 27.5%?
stoner - i've been caught for this before by the flash of ginger 🙂
and i'm anal about these things !
I can bore for medals on bike bits, but you must be roaring company down the pub! 🙂
fortunately, my mates are hewn from the same cloth, if not worse 🙂
You need to learn how to ride a bike with a low BB. Give it time and don't run a compromised shock setup as that's cheating! My 8" travel bike has a BB lower than yours and I suffer barely any strikes.
solamanda - i hear you.......... thanks for the advice - i'll keep perservering 😀
solamanda - btw - the AM has a 14" static BB height.
Do you get fewer pedal strikes with the ccdb than the monarch?
not when i was running 40% sag - swapped springs today and wound up the preload to 30%ish - will thrash tomorrow gamo.
My UFO is currently set to 13.5", so low the bash ring strikes if both ends bottom out!
