cassette and chain ...
[Closed] cassette and chain life
[#1726810]
How long should a cassette last if cleaned after every ride and the chain changed before its ****ed? (obviously an ambiguous question - but ball park figures please)
Posted : 21/06/2010 8:58 pm
Several Peaks rides at least.
Posted : 21/06/2010 9:00 pm
Same chain and cassette on my Mr Hyde - and before that my Stumpy - 2 years and still going strong.
I wipe the chain down and lube after every ride, also take the chain off and degrease/re-oil every 3-4 weeks. Also make sure you wipe off the chain rings and cassette as lots of grit gets caught in between the teeth and rings.
Posted : 21/06/2010 9:07 pm
what sort of mileage are you talking about tho?
Posted : 21/06/2010 9:10 pm
cassette life in days = miles per ride/rides per week x puddles per ride + sheep spotted * the cost of the cassette
Posted : 21/06/2010 9:11 pm
Depends on riding conditions. Been through chains in less than 500 miles. Don't think the cleaning has that much to do with it.Cassette will last a bit longer if you are replacing chains at 0.75
Posted : 21/06/2010 9:13 pm
since changing to using putoline chain wax instead of finish line I hae gone from 500 - 1000 mile life to several thousands of miles
edit - thats changing them at 0.75% worn so 2 or 3 chains to a cassette
Posted : 21/06/2010 9:27 pm
I reckon I get c. 700 miles out of a chain and cassette with a fairly lax cleaning regime but I change them before they wear the chainrings out too much
Posted : 21/06/2010 9:29 pm
It's one of my 2 main bikes, so doing about 80-90 miles a week, split between 2 bikes. That's 40 miles per week, 2000ish miles per year, so 4000 miles? That's pretty good methinks 😀
The chain and cassette are pretty worn - tried a new chain on the cassette a little while back and it skipped merrily, but with the old chain it shifts fine and is causing no problems. Will probably be buying a new cassette in the next month or so though.
Oh, and i do think cleaning makes a difference - I soak the chain in white spirit (filter and reuse the same stuff) and the amount of crap that comes off what looks like a not too dirty chain is amazing, and all that stuff is going to be grinding away inside the links/rollers. Also most people don't clean their cassettes properly - spraying liberally with GT85 and running a cloth between the cogs cleans up a lot of gritty dirt that will add to wear.
Posted : 22/06/2010 12:27 am
i dont oil my chain at all, just clean the lot and when it looks brand new again just leave it all shiny
Posted : 22/06/2010 12:54 am
This time of year I take the chain off every other ride or so. Into White spirits and then a re lube. In winter it shifty conditions I do the same thing after every ride. Chain and cassette last me about 9 months. Ride up to 60 miles a week of road
Posted : 22/06/2010 7:14 am
I change my chain and cassette at the same time, the trigger for the change is the second time that I split the chain cranking it (or when they feel like they are about to). They normally last around 6 months of riding 2 or 3 times a week in the lakes (I ride 4 or 5 times a week but have more than one bike) (when I lived down south and rode mainly in the Peaks and at Cannock and Chicksands it was more like a new chain and cassette every 2 months).
I hose my bike down when I get home, and lube the chain.
Posted : 22/06/2010 7:29 am
I did this on TJ's recomendation, 1 muddy 25mile ride at Swinley still killed a new chain and cassette enough to stop a new chain shifitng properly, no skipping, just wouldnt shift 🙁
Posted : 22/06/2010 11:42 am
