Carbon steerers on ...
[Closed] Carbon steerers on cross forks
[#3372981]
Any issues if used beyond the realms of racing? Not proper mtb trails but actual offroad riding
Posted : 21/11/2011 1:39 am
that is enough ! 8)
Posted : 21/11/2011 6:48 am
 aP
No.
Posted : 21/11/2011 7:30 am
Shaxi, don't follow what you mean?
Posted : 21/11/2011 7:55 am
Plastic with string in it(aka CFRP):
“Brittle behaviour is an unavoidable feature of the CFRP. It is necessary that the polymer matrix be glassy; otherwise, the flexing of the tubing during use would dissipate energy. That is, the bicycle would have a “spongy” feel to a rider. Because the polymer matrix is not viscoelastic, it cannot act as a microcrack arrestor when the fibres start to break. The result is that the CFRP used for bicycle tubing is inherently brittle (as opposed to fishing rods or vaulting poles, which are intended to be flexible). Because of this behaviour, it can be risky to make a component like the front fork of a bicycle out of CFRP. Front forks can receive large, sudden loads, and a brittle failure here would obviously threaten rider safety.”
Introduction to Engineering Materials: The Bicycle and the Walkman.
C.J.McMahon and C.D.Graham
Posted : 21/11/2011 8:01 am
If practice always followed theory the world would be a different place
Posted : 21/11/2011 9:43 am
following from kinesis FAQ
How many ‘Stack Washers’ can I use on a carbon steerer?: We recommend 40mm maximum. Any more than this can cause undue leverage and stress on the steerer and will invalidate fork warranty.
so i guess they feel are some issues
Posted : 21/11/2011 12:15 pm
When I first cut mine I failed to read that part in the 'instructions' and the consequent movement when I grabbed the bars and pulled them around was like a ball joint. Took 20mm off and they're fine - slammed for over three years now without any breakages.
Posted : 21/11/2011 12:57 pm
Ride my cx round the Peak with a carbon fork + steerer and did the 3Peaks CX this year. OK so far (touches wood). I think the fact that you are on a cross bike limits how hard you'll hit the rocky stuff to some extent (does for me anyway).
Posted : 21/11/2011 12:58 pm
Interesting quote MacAvity.
Have you thought about the thousands of all-carbon forks in use at the moment?
Posted : 21/11/2011 1:02 pm
