I've always been indifferent to carbon but I'm starting to think I'll see the advantage of plastic rims. Usually when I'm sitting in the garage carefully bending back the edges of my alloy rim with an adjustable spanner.
I bought a bike that came with perfectly decent DT 350 hubs but absolutely chod E Thirteen rims. They've needed a lot of attention keep them true and I've thoroughly deformed the edges. This is just at trail centres with Covid lungs, I haven't even got back into 'proper' riding yet.
What I should do is have the hubs lovingly hand built into a pair of XM481's and go on my way. They'd be perfect.
But... I'm feeling fruity and I can't stop peeking at carbon options. I've got a brand new pair of Rimpact Pro inserts and Exo+ tyres on order. I'd rather fit them to nice new rims than preshagged E Thirteens.
This is my current favourite option- https://www.scrubwheels.com/product-page/Scrub-Carbon-Enduro-Wheelset
Go on, tell me I'm wrong.
I've just gone back to Aluminium rims after a couple of years on Roval carbon wheels - which are considered pretty good by most standards Reasoning was that I did find that boost hubs on 27.5 carbon rims made for very stiff wheels that sometimes meant that the tyres struggled. There's little to no compliance, so the the thing that gives way first is they grip on the tyre. They needed trueing much more than regular rims, again the rim is stiff, so the spokes tend to take up a lot of the battering that a more compliant wheel would absorb. The rear of mine cracked, it was replaced under warranty, but otherwise would've been more expensive to replace. They scuff up pretty fast, so they do look a bit shit after a while.
personally. having had carbon rims for a couple of years, I'm not sure I'd spend the money on another set.
I have a slightly different experience...they build up really easily to a good wheel with even spoke tension as they're really stiff. Load is distributed across a lot of (evenly tensioned) spokes so they don't go out of true and theoretically spokes will last longer as they won't fatigue so quickly
But they do crack if you hit them hard, in my case on a sharp edged rock, requiring a new rim @ £250 which was slightly discounted in my case. More if you don't build it yourself of course. I'm still on the fence, and I don't dent alu rims much... In your case I'd stick with alu, or go with 100% no questions asked replacement guarantee carbon rims..
E Thirteen known for being cheese. Just build up on DT XM481 or EX511 if you want tougher. Think of the money you will save 🙂
I've got 2 sets of carbon rims, love them both. Both are around 1700g for the wheelset, the oldest ones are 3 years old and zero issues. They don't bend like alloy, and you have to be doing some pretty atrocious stuff to them too break a carbon rim these days.
I've recently bought some carbon rims from Light Bicycle. So far:
- Great service re comms and info on their website, but the delivery is not quick as they make each rim to order and then ship from China
- You do notice a difference in weight, but only when accelerating or on a hill, and then it's only minor and even then only when you first change from a heavier rim! I completely take it for granted now lol
- I didn't notice any difference in stiffness or comfort. Maybe it's the way I've laced them, not sure. These are the first rims I've built with offset spoke holes, so the tension is much more even between drive side and non-drive side, so maybe that makes for a more compliant ride?
- I'm a bit annoyed at how quickly that got marked. They looked so lovely when new, but started showing scuffs very quickly after some very non-challengimg rides
Overall: not sure if they are worth the price (~£350 for 2x rims inc shipping and taxes) but I'll prob buy them again at some point down the line!
I've got light bicycle rims on a couple of bikes and really like them. Whenever I consider building a new bike, I default to those. Wheels have been stiff, true and reliable.
One other advantage is 8 can order them with a UST sealed rim bed. Bit more involved to build (but I like building wheels) but means no need for rim tape. Only a small thing but makes swapping tyres a little easier.
They've taken a few knocks and even chipped the top laminate but I've just touched them up with 2 part epoxy
Get some DT FR rims... you don't even need a tyre.
OK tongue in cheek about the tyre but this answers most of the issues with the E13 rims...
I've got 511's and I've ridden big jump lines landing on roots and square edge wood with no air and just an insert casing everything (because I couldn't go very quickly) and ZERO damage to the rims...
That's pretty much any factory built wheel to be fair.... even an average amateur wheel builder will build a much better wheel than machine built.
I do have some carbon rims... professionally built 6-7 yrs ago and they have barely been touched... every new factory built wheel I ever had I undo until zero tension and just rebuild from there....
Switching your DT350s for some Novatec* things? Pass on that, at least get the hubs built onto the rim of your choosing (be it aluminium or carbon)
*or similar
We have been running carbon wheels for quite some time on all our bikes including the Emtbs. Never had a problem and all of ours have had quite a bit of hammer both in the UK and abroad. We have a mixture of Sixth Element, Rovals and a set of Nextie. All 29er until recently as the latest Ebikes are mullet.
We have a set of DT EX511s built up in 2017 just in case we needed a spare set of wheels on our travels. They are still hung up in the garage unused
I cant comment on the Scrub wheels you have linked to. Our Rovals are what's come with the bikes and the Sixth Elements have a Lifetime warranty but not needed to use it. Would happily recommend them.
I've had my roval control over a year now and I'm happy with them. Managed to break a spoke at ard moors last week but it stayed true. The rims are scuffed up but they still look nice in raw carbon finish. Ride feel is good. Noticeably stiffer/more direct at first but not in a negative way. So they've worked well for me. But if you're a rim bender then I'd just go for dt as suggested for peace of mind.
If I bought the Scrub wheels I'd be speccing Pro 4 hubs.
Get some DT FR rims… you don’t even need a tyre.
No one needs to sell me on DT Swiss rims, I'm already a big fan. My last set of XM481's were light, stiff, lovely to ride, took an absolute pasting in the Alps...then got nicked. Wish I still had them.
EDIT: Bollocks. The Scrub wheels I was looking at are coming up at £895 with Pro 4 hubs. It might be my imagination but I'm sure they were £850 a few days ago!
I'm a big fan of carbon rims, been using a set of Reynolds Enduro Black Label over 3 years. They've taken some truly horrible abuse, yet barely have a scratch on them.
Some things worry me about these Scrubs though, 1) I've never heard of them, 2) no weights are listed, which is odd as this is a key benefit of carbon over alloy, 3) How come they are so cheap compared to other carbon wheels out there, with the exception of Hunt, whose carbon wheels are relatively heavy.
In truth, personally I can't notice any difference between the Reynolds carbon, and my alloy DT Swiss on my other bike when riding the same trails.
AS you already have decent hubs, in your position I'd re-lace those with the XM481's that you fancy and save the cash for your next energy bill.
Now that’s an awesome stealth advert 😉
I just checked out Sixth Element and blimey, they're more expensive than I thought they would be! Does anyone know what rims they are? They look exactly like Light Bicycle. By the time you've paid an extra £100 for crash replacement they're getting on for Santa Cruz Reserve prices.
last year sixth element had some really good discounts on carbon wheels at tweedlove.
If you buy carbon rims remember to buy a spare rim for when you break it. Chances are you won't be able to get a match in the future.
This isn't the case with alloy rims.
Alloy rims have come a long way recently and there's not that much in it anymore.
I think carbon rims make a lot more sense on a road bike as you go for deep section rims for aero.
I'd just go for a decent dt Swiss rim to suit your riding style at the preferred weight option and build those into the 350s. Or just buy a new pair of dt Swiss wheels and sell yours and save the hassle of building wheels.
You've not seen the state of our garage loft. We never seem to get round to selling stuff, when we do it just builds back up. Peatys Bike Bonanza has always been a God send for us due to no advertising, no photos and no posting. It was postponed last year and due again this year in November. Fingers crossed it goes ahead.
I've carbon rims across three bikes - made sense for the weight saving on the fat Ike and aero advantages on the road bike, but the trail/Enduro I'd prob go with alloy if your heavy on wheels and constantly bending back the alloy ones you currently have. I've cracked a rim and it's not cheap, quick or easy? to replace - I had to wait a month for a spare (£250) and pay for a rebuild.
If you do go with carbon definitely use impact strips.
Just don't go for DT Swiss carbon. They have a "warranty" on them, but it doesn't cover riding on a surface with loose rocks, ie mountain biking.
Not any lighter, don’t ride as well & have broken considerably more carbon wheels than aluminium. They are pointless on an MTB that gets a bit of stick IMO.
The other set are still working awesomely... don't think I've had to touch a spoke and they have seen abuse only possible with my crap riding. The rear has been swapped onto Jnr's bike on several occasions and he can wreck a wheel in a day...
This thread came at the right time as in looking again for a carbon set.
Ive been tempted by the Blue flows which a friend uses and he praises them highly.
Reserves ive know a few people who have killed them BUT replacement rims have turned op very quickly.
I have used Bontrager line carbons for 18 months, and with a few marks and scratches they were brilliant. Light and stiff. I really have felt the difference moving back to alloy rims. Ive looked at the Nextie rims and sixth elements but cant help wonder are they just re labelled Chinese rims. I will keep an eye on this thread for further insight.
I love carbon rims on both ebike and acoustic bike. The stiffness and more bombproof than Ali in my experience. Seen wheels explode casing jumps at my place but carbons rode it out
thats do do with the build and blind luck mostly. although pinned ali rims will fail easier than welded.
Usually when I’m sitting in the garage carefully bending back the edges of my alloy rim with an adjustable spanner.
if you are doing this with an ali rim at the moment how is that new unbendable carbon rim going to fare??
i treat rims as expendable items. usually i get about 6 months of casing/battering the hell out of one before i start to look for a replacement. i suppose i could run an insert but then i`m adding rotational weight which sucks.
I have a pair of Rimpact Pro inserts waiting to be fitted to whatever I buy. People complain about the weight but they're considerably lighter than most 29er innertubes.
Never used them but they are catalogue Chinese rims branded up. Im not saying that’s a good or bad thing, just that’s what they are
Running ROVAL traverse carbon and some reserve wheels on my two bikes - fast spinning and confidence inspiring.
A mate killed front and rear SRAM carbon rims on his Nomad at Chopwell on Roots. Clumsiness on his part, but still catastrophic failures. Best bit is they were 24h, so replacement alloy rims are rarer than Brexit benefits.
On the flip side, another mate killed a DT OEM rim in the same spot the week after. Wouldn't hold tubeless, but a tube allowed him to carry on riding.
i have never had an allegiance to alloy or carbon, but i have been running Zipp Moto wheels for the last couple of years and they have been utterly flawless.
I got them used (but basically brand new) for around £700. So was quite the investment for me at the time, but as i say, they are superb. To the point that i think i would stump up the £1900 for a new set if it was ever required.
I havent used 'cheap' carbon rims, but know a few folks that do and they seem happy enough with them. Although they always bring alloy wheels when we do 'risky' events, like the megavalanche... which to me says they didnt buy the right wheels. If they are fitted to a bike to do these sort of rides, they should be up to the task... not swapped out for a cheaper alloy rim.
Another thing to consider is how hard you are on wheels. Personally, i have never cracked a rim (alloy or carbon) but have needed alloy ones trued a few times. If you dont brake rims, spending more is less of a concern. If you explode rims weekly, maybe they arent for you?!
But ultimately, if you go carbon, get good ones. Zipp, Crank brothers, we are one etc
not any lighter, silly expensive, if you bike takes any sort of a beating i wouldn't bother. They will crack and they will be expensive or time consuming to replace. Alloy all the way.
@chrismac I dare say most are rebranded China rims. The struggle will be finding the best one. Ive just been looking at a set of Nextie Rims at £450 they seem value until the shipping wait time and import duties land then maybe not as good value.
I'm with HobNob on this... Far too many drawbacks for carbon rims on MTB, far too little benefits. On a high performance road bike they make absolute sense, but there's no compelling reason to run them on an MTB that hasn't been debunked in my experience, and often proven that decent alloy rims are in fact superior in many cases.
I don't disagree with this at all, but it puts the price of entry firmly beyond the reach of most people... Which is even more of an argument to stick with alloy rims. Even working in the trade and being a total tart, I won't be convinced that any carbon rim is worth the outlay over a decent alloy rim.
Had some on my Mojo3. So 41mm with 27.5x2.8 tyres. Great build, lovely fella to deal with. They are still going strong on a mates bike. One broken spoke in about 3000km I think. They weren't actually that stiff from memory (but 2.8 / 12 psi tyres...) and still looked okay after a few years use.
But also had a set (not blue flows) on my Aires MK1.5. Cracked the rear while away in the Pyrenees (and I am not a hard rider, just clumsy). Thankfully we had driven down and had spares. Before they broke, they really made the bike feel way harsher I'm sure (was on some DT XM before I think) and weren't that light.
I switched to Newmen for my bikes now. Light, strong, well engineered, fixable. Also had a few sets of Ibis 9xx which while a bit heavier are also a great set of alu rims.
Carbon rims (Sixth Element) on the big bike, alu everywhere else. Love the carbon rims, love not having to true or worry about dings etc. That said, I did case a gap straight onto a sharp edge and cracked a rear (miraculously the tubeless stayed up and carried ion riding it for a week or so...) However, it was a heavy impact and I wasn't riding any inserts. Rim replaced for free (no quibble warranty) and back riding within a few days. Now with insert and no issues since. Have done the same with Alu in the past. Given the lack of maintenance required between I'd def recommend carbon.
I'm on a set of eThirteen TRS carbon wheels which came on a complete build and have been almost completely fine for the last 2 and a bit years. One broken spoke and one warrantied hub axle (quickly replaced) in that whole time and they've stayed nice and true.
All that said, if they needed replacing I'd be getting a set of alloy Newmens. Their listed weight is about the same, they have fantastic reviews and they cost far less plus they have a nice quiet freehub which appeals to me.
In fact, I'll sell you my eThirteen wheel set and buy Newmens for myself if you want.
I’ve had my roval control over a year now and I’m happy with them. Managed to break a spoke at ard moors last week but it stayed true. The rims are scuffed up but they still look nice in raw carbon finish. Ride feel is good. Noticeably stiffer/more direct at first but not in a negative way. So they’ve worked well for me. But if you’re a rim bender then I’d just go for dt as suggested for peace of mind.
This, but I've had my set for years and they were second hand, love the direct feel over the alloy wheels I removed. Have had no issues with the carbon rims and have ridden them in many places quite hard.
I love a quiet freehub
I got a set of carbon wheels (the silt AM ones) for my titan. They are way, way lighter than the ex511 I was running previously. It makes a very noticeable difference riding up hills and slogging around the place. Ui assume they're just chinese rims of sort sort despite what the marketing guff said, but they mounted up easily and did a week of me riding in Morzine like a moron with no issues.
It's worthwhile noting I'm a light rider(60kg) on a heavy bike, so that reduction in rotating mass is very welcome when you're slogging up a steep lane to get some trals. They're more pingy over roots, but not enough for me to sling the 511s back on the bike. We'll see how they do in a few years time - my riding style is best described as clumsy and my maintenace strategy as occsasional and I've turned dt swiss, stans and a few other brands wheels into wobbly 50 pence pieces in the past.
i have a pair of carbon rims from light bicycle. i bought them about 8 years ago. they are the 30mm wide cheaper option 29er. build them myself and they have been no trouble at all.
bought a new pair in the summer from another company. cracked within a month. the company i got the new ones from do free replacement for life, so got a new rim.
lucky/unlucky? who knows. i’m pleased i went with a lifetime warranty option.
I'm a big carbon rim fan, I was a pretty early adopter with the first Lightbicycle rims, purely because I had a mangled roval rim and there was literally nothing else the right erd. And it was fantastic. Broke it eventually but it'd had a long and hard life of scottish enduro racing etc and was mostly in a hardtail, and I did skelp it off a big rock. 10/10, fantastic performing thing and it was even quite cheap
Got a discount off of that on another set of LB rims, which I've broken one of- didn't actually hit anything big, I'm pretty sure it had just had enough after, again, a long life. I doubt any alu rim would have done better but there's literally no chance anything in the same weight and size class would have. Replaced that one and once again got a discount.
Then I got some super cheap used DT 1350s and, er, broke the rear rim after about 3 rides. Ah well, can't win em all! And I'm now replacing that with an XM481.
Cos, see, when I started getting the carbon rims, alu rims were nothing like as good as they are now. Probably a Flow was the best alternative and flows were soft and cracky. And you could get quality carbon for really not that much money.
In the meantime alu rims have got bloody brilliant, the current dt range is phenomenal. And at the same time, carbon's not got that much better but it has got more expensive from the same people. So it's not that I've gone off carbon, I'd still happily build another set but right now alu rims are at their best ever.
I've smashed 2 light bicycle rims, they're murder to get heavy duty tyres on with an insert and murder to get any tyre off, I have to use a spade to break the bead.
If i had my time again i'd get dt swiss alu 511/ 471 rims
2 years on a set of Blueflow carbons on a high pivot Enduro bike, smacking into everything..no insert, no ficks given. Sure theyve got scuffs and marks but haven't even been touched with a spoke key. Faultless.
I'm a big convert to carbon wheels, for me it's about the ride feel they deliver....and whilst every rims will have a different layup and wheel build, some will be direct, some will be compliant. The smooth, vibration damping they deliver is instantly noticeable for me.
I am extremely happy with my Blueflow wheels from Stuart, top guy and great wheels.
I've been running BTLOS rims for the last few months, noticed the weight saving immediately, acceleration out of corners, up hills, etc is great. £150 each for the enduro spec ones, built up to a 1600g wheelset 30mm ID rims. My thought was they aren't that much more than equivalent dt swiss ex511 at £100 each so worth a go. Dead easy to build as already mentioned.
The carbon rims are 'too stiff' isn't really true any more. Low profile carbon rims with a 6mm asymmetric offset build strong wheels with a bit of flex. This can only help carbon longevity.
Another vote for Blueflow, had them on my ebike about 12 months and not a single issue.
No insert, ride Peak/ Yorkshire etc with the line choice of a blind Rhino👍
Lovely bloke to deal with too.
I think carbon wheels helped me go from 26 to 29er. They feel light, comfy, and they rail. I don’t have experience of Al 29ers though.
Anyone remember that Danny Macaskill video where he tries to destroy a Santa Cruz rim?
Also theres a Scott Pilgrim video where he rides tyreless with no rim breakages.
Seems impressive to me but I guess they'd be the more heavy built rims for downhill/freeride/dirt jump riding.
I've been carbon rim curious for a while but the cost has always put me off. I will however be in the market for new rims on my cross bike, xc bike and LLS hardtail over the next 12 moths as the current ones are in a pretty poor condition. Probably will be going with DT Swiss as they get good reviews, would also match my road bike.
Same here. Had a set of their 29" BF42/35 'Wider' for around 2 years now. I've somehow managed to ride my bike hard enough to crack the top-tube but the wheels are perfect.
I love my DT Swiss XMC 1501 set and I’d be tempted again if heavily discounted, but I’m a bit put off by the high crash replacement cost and stories of quibbling. I think I’d look at Blueflow or DCR Wheels first.
As a heavy rider, given to thrashing bikes a bit, my carbon rims have lasted well.
I’m 112kgs and use two sets of wheels I built my self from Nextie carbon rims.
One on the 180mm travel big bike, the other set on 140mm trail bike. After two years, I’ve not needed to tweak either set and they have been very tough. Purple of scrapes here and there but still looking good.
I do however run Rimpacts in all of them, with EXO+ tyres. There have been a few thumps which have got down to the rimpacts, and hence probably saved the rims.
Carbon+inserts…. Tough and stiff.
Without inserts? Maybe not worth the risk I’d say. As a biffer.
Thanks everyone, I was offline all night after work so there's a lot of reading here!
Never heard of Silt or Blueflow but they both look like decent options.
Same here once the tyres arrive. I was hoping an advantage of carbon would be to offset the extra rotating weight while benefitting from sturdier tyres and more puncture protection.
Based on this thread, sixth element would be great only ones I'd try.
Holy thread resurrection! I've been a huge carbon rim fan for years now and now a good friend has started to import NEXTIE rims and wheel sets in the UK - it was only a matter of time. We weighed the above at 1570grams for the pair, nearly a 1kg saving on the OEM wheels! The ride feel is transformative, he's planning on offering these for circa £750, for the money I'm pleased to say the least!
