Carbon frames and r...
[Closed] Carbon frames and roof carriers.
Is it a good idea to use on of those roof carriers that clamp onto the down tube if the bike is carbon?
Posted : 13/08/2013 7:53 pm
Have you seen how thin alloy frame tubes are?
Posted : 13/08/2013 7:55 pm
Seems to be fine...2 years with mine...
Posted : 13/08/2013 7:57 pm
 aa
did you buy the colnago?
Fwiw i wouldn't attach on the roof it using the downtube. It's asking for trouble. also, if i might be so brazen....dwarf....roof....surely a towbar is more economical, easier to access etc
Posted : 13/08/2013 7:58 pm
Just wrap something like a cloth/innertube around the area where you clamp to the down tube with the roof carrier, this should prevent any rubbing of the frame!!!
aa - ๐Ÿ˜›
I'll have you know i can lift my 33lb Wolf Ridge onto the car roof (its a small car!)
Unfortunately the car has no towbar nor can one be fitted as it's a Ford Ka!
PS. - Yes, bought the Colnago 8)
Posted : 13/08/2013 8:10 pm
A man after my own hart who's bike is worth more than his car!!! I like it...
Posted : 13/08/2013 8:23 pm
It's not even my car!
It belongs to MsD - I don't drive ๐Ÿ™‚
Posted : 13/08/2013 8:32 pm
The racks that clamp a tube each side can do serious damage to almost any tube (including steel), as the leverage is very high. Thule 591's hold rather than clamp the downtube with a fixed underside and a clamp onto the topside. I've been very happy to drive through France with my 800g carbon bling frame so attached at 80 mph.
Posted : 13/08/2013 11:50 pm
I put my carbon road bike UK one for the first time at the weekend and it was fine.
My mate has used one on his Mojo SL for about 3 years now and that ain't broke
Posted : 14/08/2013 3:13 am
 Haze
No problems with the frame although you might expect the front wheel to flap around a bit, and if it's not perfectly in line on the wheel tray it'll wear a hole in the tyre.
Happened to one of our three down to France this year, the other two fork mounted carriers (561's) were fine.
Posted : 14/08/2013 7:08 am
5 years with my carbon enduro on the roof with Thule 591. No issues.
Posted : 14/08/2013 9:44 am
