Carbon fork for old...
[Closed] Carbon fork for old cyclocross frame
I have an old canondale tourer which I am using as a cyclocross frame.
I want to swap the heavy steel fork for a carbon fork with disc tabs.
The frame has a 1 inch steerer.
I was looking at options and Nashbar do one but do not ship outside the states.
Any other suggestions
Posted : 06/10/2016 10:08 am
Exotic do some 1 inch steerer MTB forks
Depends on how you feel about aesthetics I suppose
http://www.carboncycles.cc/?s=0&t=0&rb=14&#MTB_Carbon_3K_with_1.1/8_inch_Steerer
Posted : 06/10/2016 10:36 am
Looking for 700c forks.
Did the 3 peaks cyclocross this yearand they stipulate that you need 700c wheels.
Posted : 06/10/2016 11:02 am
 goss
Croix de Fer owners (including myself) have the same problem.
straight 1 1/8" steer, disc tabs (post/IS don't care), room for 35-40c, qr/15mm axle.
Right now the only option that suits the purpose is the pricey Ritchey
http://ritcheylogic.com/wcs-carbon-disc-cross-bike-fork
Posted : 06/10/2016 12:49 pm
You can get those Exotic forks linked above in 1 inch steerer, 46.5cm length (i.e 700c).
[url= http://www.carboncycles.cc/?s=0&c=82&p=966&tb=001 ]http://www.carboncycles.cc/?s=0&c=82&p=966&tb=001[/url]
Posted : 06/10/2016 1:01 pm
Road / CX forks generally 400-420mm a/c dimension - a 460mm fork will result in a 2-3 degree 'slackening' of HTA which will change handling. Think there's a shorter version.
Posted : 06/10/2016 1:07 pm
 kilo
Goes fat bird cycles had a 11\8 straight fork van Nicholas which might be of use
Posted : 06/10/2016 1:27 pm
OP I assume you need canti bosses?
Otherwise those Exotic forks come in a good range of lengths
Posted : 06/10/2016 3:10 pm
[quote=kilo ]Goes fat bird cycles had a 11\8 straight fork van Nicholas which might be of use
Not if there's a 1" steerer tube
Posted : 06/10/2016 3:47 pm
eXotics on eBay come in 39, 42.5, 44.5 and a 29er length Axle to crown.
The best product I've found is £136 carbon bladed number on bikediscount.de, 40cm. These are all to fit my 1&1/8th not 1" sorry.
Posted : 06/10/2016 4:57 pm
Exotic do a 1" carbon fork 39cm axle to crown with disc mounts
The also do it 42.5 cm
Posted : 06/10/2016 5:27 pm
