Carbon fork bung/ex...
Carbon fork bung/expander - long/grippy
Eldest has enthusiastically tightened his loose headset on the road bike and pulled the steerer bung a bit.ย
I've reset it BUT I don't think it's gripping especially well.ย  I suspect it's just "polished" the inside of the steerer when it slipped.ย ย
I'd like to put in a longer / especially grippy one that might get below the existing one (about 40-50mm).ย ย
Has anyone found any especially reliable ones?ย ย
Deda Elementi is available at 70mm but even a touch longer would be good.ย  1 1/8 steerer.ย
Thanks
Posted : 04/04/2026 6:04 pm
I changed the one in my Digger. It was about 30mm I think. I got one on ebay that was 50mm for a fiver. It's been solid for the last 2 years.ย
I've just checked and they do 80mm also. There seem to be lots of sellers selling them.
Carbon grip paste will also help.
Posted : 04/04/2026 9:06 pm
Yes, assuming carbon steerer, you need something that reaches below the stem to support the steerer, typically 40-50mm.
Choose something that expands over its whole length, again for support, rather than just the bottom third.
Some lightweight ones keep the expansion part small, but unless the remaining two-thirds is a snug fit in the tube it won't provide support.
The Deda Elementi Expander 45 fits the bill IMHOย
Posted : 04/04/2026 10:10 pm
Brilliant thanks both.ย  ย
I found a 70mm version of the Deda one on Amazon.ย  I'm aiming to have a bit of grip below where the existing one slipped from and plenty of carbon grip paste stuff.ย ย
Hopefully that'll sort it.ย  👍
Posted : 04/04/2026 10:50 pm
Finkill reacted
Don't overtighten it, the bung can expand the steerer (it's a problem if it's excessive). Some manufacturers can over specify; Deda recommend 3Nm
Drop a spacer on and gradually tighten the bung to single figure Nm; you'll feel when the steerer is expanding by sliding the spacer up and down as you go
Posted : 05/04/2026 8:22 am
@timba
Thanks for the tip.ย
I've not got a torque wrench (I should treat myself really - cue a what torque wrench thread 😂) but it's a good thickish walled tube on his Felt. I did leave the stem in place while fitting and no additional friction in the bars flopping around once fitted.ย ย
This model (maybe as it's a longer version) seems to be maximum of 5Nm.ย  If I'm over it's not by much so I'll quickly check it with a spacer now and then get myself a torque wrenchย  (should have done ages ago) and check on it more precisely later in the week.ย ย
Posted : 05/04/2026 4:34 pm
