Carbon fiber bike w...
[Closed] Carbon fiber bike wheels for sale
That narrow brake track was substantially thinner than most tires, so if you took a slice of a toroidal wheel with a tire mounted, you would have a football-shaped rim with a waist above it, then a broad circular tire. Only the deep section of these wheels was truly toroidal; with a tire, these wheels were in fact shaped like an “8.”
[url= http://www.discountcarbonbicycle.com/29-mtb-carbon-wheels-clincher-28mm-with-novatec-hubs/158.html ]Carbon fiber bike[/url] Hed Cycling and Zipp both used a similar tactic to solve this shortcoming: they made wider rims. The old standard width was 19mm. The current Hed Stinger 9 is 28mm across at the brake track. Zipp’s 404 is broader than 25mm at the tire bed.
The idea behind widening the brake track is simple. The tire itself is 23mm across at its broadest point. In order to create a continuous, smooth shape reminiscent of a football with both the rim and tire, the rim must be wider than the tire so the rubber doesn’t protrude past the sides of the wheel. Designing the rim around the tire worked. This newest generation of wheels is substantially more aerodynamic than the pre-2007 wheels.
This change in design provided a very clear lesson about http://www.discountcarbonbicycle.com aero wheel design: Integrating the tire and rim is crucial.There are a bevy of genuinely fast aero wheels now—Bontrager, Enve, Shimano to name a few—that are designed around the principle of broadening the rim to create a toroidal-like shape of the wheel and tire in combination, and Mavic is taking this concept to the next level.
The historic French company created the concept of building wheels as a complete system—rim, spokes and hubs—in 1994. Before then, wheels were assembled from their individual components. This idea revolutionized cycling wheels, and now practically every bike rolls on pre-built wheels.
The French company announced their intentions to do the same with tires in 2010. At first, the change wasn’t that big. Instead of build wheels and tires separately, high-end Mavic road wheels now came with tires.
[url= http://www.discountcarbonbicycle.com/29-mtb-carbon-wheels-clincher-28mm-with-novatec-hubs/158.html ]wheels for sale[/url] The idea was valid, but it was being applied in the wrong arena.
Posted : 31/08/2012 10:09 am
You misspelt 'frames' on the website. I find good spelling is key to scamming.
Posted : 31/08/2012 10:22 am
