Canyon Nerve AM Bot...
[Closed] Canyon Nerve AM Bottom Bearing Help.......
Having a blonde moment here. After trawling around i bought the Superstar angular contact bearing 40x52x7 45x45 degree to replace the crappy Arcos one that fell apart.
The problem is the bearing seems to sit on a lip and does not go into the frame as seen in pic 1
When the bearing is inserted as far in as it will go it ends up looking like this
Am i missing something here?
Posted : 16/03/2013 6:08 pm
Rather than 'missing something' I'd say you possibly have too much?
You say the old bearing fell apart - is that part of it still in the frame?
Edit to add - actually it doesn't look like the old bearing race... Do you still have the old bearing to compare the new one to?
Posted : 16/03/2013 7:30 pm
Canyon say the bottom bearing sits into the frame without a Cup, It's semi-Integrated. The old one is the Ball bearing version.
The lower headset is integrated 52mm headtube internal diameter and 40mm steerer diameter so there isn't a cup and the bearing sits directly in the headtube however mine wont as it sits on the Lip in pic 1
Posted : 16/03/2013 7:54 pm
Old Left New Right
When i google ACROS AI-03 The baring is the same as the one on the right and not the ball bearing that i have removed?
Posted : 16/03/2013 8:12 pm
O dear.... ๐Ÿ˜‰
Posted : 16/03/2013 8:14 pm
the old outer race is still sat in the frame you will need to get it out either with a puller or a hammer and a drift or something
Posted : 16/03/2013 8:15 pm
Cheers Sancho.
Posted : 16/03/2013 8:20 pm
