Cantilever brakes.....
[Closed] Cantilever brakes...
I'm setting up an old bike (GT all terra?) as a singlespeed runabout.
The front brake bosses have the mounts with the three small holes beside them so I was able to set up some tektro V's there no bother.
However the rear brake bosses have no three small holes and so my brakes won't fit.
Can anyone suggest a solution or perhaps link to a set of cheap, suitable brakes that would work on the above described mount?
Conor
P.S. I was originally intending to just use a front brake, however today after coming over 2 sets of curbs I reached for my brake to find that the noodle had popped out on landing and I had to use my front wheel along with my hand against a pebble dash wall to stop...
Posted : 23/07/2009 7:46 pm
 Bez
Old GTs (up until about 1992ish) used U-brakes on the rear... If it's a U-brake mount the bosses will be further from the axle than the rim is (as opposed to canti mounts which are closer). You can still get them - Dia Compe and/or Odyssey I think.
Posted : 23/07/2009 7:56 pm
Odyssey Evolver U brakes were the ones to get last time I checked (about 8 years ago ๐Ÿ™‚ ). You might be able to use the spring hanger/holder from a U brake with a V or canti if the posts are in the right place for Vs (U brake springs are held in tension by friction).
Posted : 23/07/2009 8:36 pm
