http://www.chainreactioncycles.com/race-face-press-fit-30-x-type-bb-adapter/rp-prod106657
Don't know if this is any good as a BB replacement?
Anyone?
Anyone regreased all the pivot bearings on a trigger themselves? Sent it to NWMTB last year, but fancy doing it myself while I've got time. Also, what grease would you recommend?
Apologies if this has been done in the previous 56 pages BUT...
[b]Can I run a full internally routed dropper in my large Trigger....and will 1.5m cable be enough?[/b]
I thank you...can I have a quick answer please? 😉
Yes you can. I've just done it with the seat post recommended on your seat post thread.
Cheers Hammer - is that the bike you're running yours on.
Yes. But a medium, plenty of cable trimmed off though.
If you read up the page a bit I ask the question about internal cable routing.
Ha - there it is just half a page further up! Chees Hammer - think I'll go for it with ubyk.
Just in process of installing internally routed dropper.
Undid lower shock bolt to make it easier to thread hose through...not sure if I've taken a rubber bung off and lost it or if there was ever one there at all...must be though or frame would fill with water! Can anyone confirm either way ASAP please? Might need to source one as I can't find it..any suggestions?
No I don't think there was one. I thought there was, but when I was checking something out the other day there wasn't one there.
I didn't remove anything and just taped the old and new cable hoses together and pulled one through with the other.
PSA: Paul's have got the 2016 model in stock and on sale. £2380 for a carbon Trigger 2 🙂
I have a rubber bung on mine, still fills with water though.
Cheers longmover - think I may have located mine and good to know there is meant to be one.
Going 1 x 11 on my Trigger. Looking for a cassette with expander ring. What are you guys using?
I changed to a mixture of Sram NX and GX, NX cassette and crankset, GX rear mech and shifter. NX cassette means you don't need to change wheels or freehub.
Cheers, will have a look at those.
Will the Sunrace mx 8 11 speed cassette fit ok guys?
Anyone know where I can get a frame grommet for my Trigger? Need one for my seat tube...it's a kp312 - tried Cannondalespares (revel sports) but no joy - their suppliers are out of stock too. Anyone have a spare they don't need they'd be willing to part with? Any suggestions welcome - cheers
I'm looking for a size large Trigger frame only if anyone happens to selling? Apologies for the stealth wanted Ad!
how much?
I cracked my Jekyll (as reported earlier in this thread) the warranty replacement 2016 frame arrived last September but I'd already bought a replacement frame by them.
I'd lost faith in the Jekyll due to it cracking and also not really gelling with it. I've advertised the frame & shock since then on Pinkbike/Stw/Gumtree/EBay for £550 and not had any interest, I'm not selling for less than that as it's pretty much just giving it away so I'm building it back up mainly because I actually like the new 2018 Jekyll and I'm hoping mine cracks again so I can get one as a warranty return!
Does anyone know if a Trigger 27.5 will take a 203mm rear disc?
Yes it will, with the right adaptor.
180mm max on the front if running a lefty.
Wonnyj are you selling your trigger frame?
Excellent, it's a fox on the the front so 203s front and rear.
I'm not selling mine. Just saying that I've bought one! Awesome bike so far.
Hi guys,
I'm tempted by the current offer at Paul's for the Trigger Carbon 2 but am being put off by the fact the DYAD has been discontinued. Do you think getting the shock serviced/replaced will become a problem?
Would I be better off looking for something a bit more conventional but lower spec at the same price point?
Also, has anyone cracked a carbon frame and, if so, what did it take to do it?
I can't see Dyad servicing being a problem for a few years.
I have a Trigger 4 - couldn't go 203 at the back as it will foul the non-drive chainstay.
Settled on 180 0r 185 - can't remember which! Plenty of power even with SLX.
Cheers. Some how I came across the pic earlier iPod in the thread using the post adapter to fit a 180.
I'm 203 front and back. No fouling. Not even close. Mandatory to fit my Hope E4s as the bulky calliper wouldn't fit on the stock mount.
@zero-how did you get a 203mm rotor on your lefty?
Anybody with a carbon 27.5 model know which bearings I need? time to sort the creaking out, but the interwebs is inconclusive on what bearings are needed on a 27.5 carbon frame...
Looks like the info is in the user guide - ignore me!
Where is the user guide to be found? Mine didn't come with one and my basic internet search skills bear no fruit.
My guide was in the box of 'bits' that came with the bike - tubless valves, hub adaptors, shock pump.
[url= https://www.google.co.uk/search?q=cannondale+2015+user+guide+trigger&ie=utf-8&oe=utf-8&client=firefox-b&gfe_rd=cr&ei=AMVHWb21MfHGXp2Wt8gK ]Link - parts list on page 18[/url]
Nice one thanks. Wasn't in my box!
180mm disc fitted on the rear. Noticeable improvement over the 160mm.
No to test it in anger @les gets on Friday.
Changing the mavic crosroc wheels on my trigger at last. Got the rear hope enduro on and just waiting for delivery of a Boone Supermax hub to build up the front 🙂
That looks a giggle.
Needs a lefty but I like that.
Couple of things...
Just noticed a bit of play developing in rear end of my Trigger 4...hoping it's a relatively easy fit and thinking most likely cause are the shock bushings rather than any bearings.
Anyone had to replace bushings/bearings? Easy fix?
Secondly - rode 2 mates' bikes this very briefly this weekend which both had Pikes up front - they feel much nicer than my Fox 32s...anyone else swapped or is it worth tinkering with pressure to make them feel nicer?
Trigger performing well at les gets. Had a nosey in the cannondale support tent for the passport du solei. The new triggers and jekyls look really nice. Very tempted to get a jekyl.
