Cannondale owners: ...
[Closed] Cannondale owners: Who do you recommend for Lefty and Fox Dyad servicing?
Had my Trigger for about 5 months and I think it's time to think about the first service. Who is the go to guy for Lefty's and Dyads in the UK? And any idea of the costs of a basic service if all is OK?
Thanks
Posted : 22/08/2014 12:26 pm
Pretty sure Mojo are the only people for Dyad servicing. The guy at Evans has a great reputation for Lefty and Headshok servicing and been doing them for donkeys years.
Posted : 22/08/2014 11:30 pm
Thanks. When you say 'Evans' is that the online store thingy?
Posted : 23/08/2014 5:30 am
The Lefty may only need a bearing reset.
The new versions are simple to do at home. It should not need anything else after only 5 months.
Have a chat with TFTuned if you are not sure.
Posted : 23/08/2014 7:55 am
Evans in Kendal for the lefty if it needs doing there a lot cheaper and do a better job.
Posted : 23/08/2014 8:00 am
IIRC the design was changed in 2012ish so the bearing cages self-reset (the same time the rubber boot was dispensed with).
The confusingly-named Leisure Lakes Nottingham (which is in Derby) did my service, and did a good job. Incidentally, TF will swap dampers, eg. changing a DLR for PBR.
Posted : 23/08/2014 8:15 am
Thanks to all for the info.
Posted : 23/08/2014 3:38 pm
The design was changed but you still need to do a reset.
It's just a lot easier and can be done by anyone at home.
See page 18 of this PDF.
Posted : 23/08/2014 3:52 pm
That's not dissimilar to the procedure for my 2010 DLR Lefty (which could still be done by anyone at home), except they've lengthened the interval to 50 hours. In this [url= http://www.bikerumor.com/2012/06/23/2013-lefty-forks-stiffer-lighter-stronger-more-durable/ ]BR post[/url] about the 2013 forks, it says that bottoming out the fork is meant to reset the bearings automatically.
Posted : 23/08/2014 6:24 pm
Only if you bottom out hard enough. I am 70kg, get full travel, but don't seem to reset the bearings. Air out and squash job does it easy though ๐Ÿ™‚
Posted : 23/08/2014 6:49 pm
