Cane Creek shock bu...
[Closed] Cane Creek shock bushings
I need a bush for a CC shock.
The bush has an 8mm hole for mounting bolt.
The bush is 12.7mm diameter (cc standard?) and the width for the linkage is 30mm.
The tft site doesnt list a 30mm wide bushing. So what do i do?
thanks
Beener
Posted : 12/11/2018 8:18 pm
Phone JTech
https://j-techsuspension.co.uk
They'll machine hardware to size and are generally very helpful and nice.
Posted : 12/11/2018 8:28 pm
(cc standard?)
No such thing, they use different ones on various of their shocks.
Posted : 12/11/2018 8:53 pm
What bike is it for?
Posted : 12/11/2018 8:56 pm
Also by bush do you mean the hardware that the bolts physically go through rather than the 'wearing' bush which is pressed in to the eyelet.
Either way, James @ JTech will see you right.
Posted : 12/11/2018 8:57 pm
ah...i may mean the hardware that is pressed in. I got confused with looking at 'offset bushes'.
thanks for your help
Posted : 12/11/2018 9:02 pm
If you mean hardware, I'd also recommend Bounce Suspension.
They make very nice, reasonably priced stainless ones - plain or offset.
Posted : 12/11/2018 9:29 pm
Its for an older Cube Stereo hpc 160.
So, just to clarify......the shock has a cast eyelet at each end. Into that is pressed a bush (the thin walled tube). Then there is the mounting hardware, which is a solid bar that is drilled to accept the mounting bolt?
Is that all correct? Before i phone Jtech and sound a numpty.....
Posted : 12/11/2018 9:54 pm
 ART
https://www.tftuned.com/tf-tuned-mount-kit-127mm-m8/p2937  if it's a CC Inlne just pick M8x30
Or if it's a DB Air/ Coil then pick M8x30 here
https://www.tftuned.com/cane-creek-2012-mount-kit-m8/p2934
You're welcome.
Posted : 12/11/2018 10:26 pm
@ART.....Many thanks!
Beener
Posted : 12/11/2018 11:08 pm
Get one of these as well
https://www.tftuned.com/bushing-tool-for-127mm-bushings-and-cane-creek-2012/p3156
If if it’s a metal eyelet within the casting on the shock body you’ll need to get that out as well. That’s a bit that wears and if you put new mounting hardware on a worn bushing you might still feel play.
i use the low friction kit from tf and that just pushes in really easily.
Posted : 13/11/2018 8:08 am
