Can You Run 1*9 For...
[Closed] Can You Run 1*9 For XC Without a Chain Device?
As the title says really.
Would be going on a hardtail with a dh/slalom chain ring so bigger teeth than one designed to shift.
Thanks
Dave
Posted : 19/01/2011 12:36 pm
Depends on the bike in my experience. No probs on my Pegasus, but the chain used to drop all the time on my Prince Albert. Probably down to chain tension I suspect...use the smallest rear mech you can get away with
Posted : 19/01/2011 12:40 pm
Is the weight loss really worth the risk of smashing your nads into the top tube or stem? Even CX racers have some form of guide when running a 1x setup
Posted : 19/01/2011 12:49 pm
Some people on here swear you can.
Speaking from experience, you can't if you want to ride anything remotely rocky/rooty/bumpy or anything at speed.
As a minimum, I'd want a Superstart XCX type thing which I'm going to get on the hardtail. MRP Mini-G2 on the full sus and thats perfect.
Posted : 19/01/2011 12:52 pm
 s
The simple answer is yes.....right up to the second when your chain flicks off for the first time on that nice rocky DH section, then funnily enough it becomes a definite NO for some reason!
๐Ÿ™‚
Posted : 19/01/2011 1:00 pm
Yes, I have two that never dropped a chain, Zion 29ner and Whyte 19, both on short mechs. But a couple of the devices are so good, relatively cheap, easy to do I would should have one on my bikes. Both bikes go down the 'softer' local DH tracks and jump off 'small' things.
I do have have two an E13 and the latest Superstar version and they are sitting in the tool box waiting for the day a chain comes off and I come home to fit them!
Posted : 19/01/2011 1:07 pm
Trying this our at the moment on my full sus, e13 chainring so longer teeth but it still comes off once a ride or so. Would be sorted if I could get one of those "Paul's" chain keepers to sit on top of the chainring.
Posted : 19/01/2011 2:08 pm
