Can you recommend a...
[Closed] Can you recommend a tubelss 29er tyre for the road
going tubeless on the crosser project but need a tubeless tyre to fit the stans crest rims, needs to be super fast rolling as i'm doing more commuting than off road but i'll still need one that will handle tracks
ta
Posted : 16/04/2011 12:15 pm
Dunno re tubeless but the
Posted : 16/04/2011 1:34 pm
UDunno re tubeless but the widest cx tyre I could find this week was
Posted : 16/04/2011 1:39 pm
Dunno re tubeless but the widest cx tyre I could find this week was a conti 42
Posted : 16/04/2011 1:42 pm
Pick your tyre and just convert it. I'm commuting on 28mm Gator skinz on an Arch rim with yellow tape and valves. Run them at 80 psi and I'm about 15 stone. Works a treat.
Posted : 16/04/2011 1:50 pm
cool
Posted : 16/04/2011 2:02 pm
Oh, but I did pick the steel beaded ones just to be safe.
Posted : 16/04/2011 2:08 pm
 DIS
I have just fitted schwalbe marathon extreme 1.6 (42cc approx)to my 29" crest rims set up tubless. Inflated with out problem using track pump. Not to heavy, roll well but still have a good bit of grip for off road. If thats to wide they do smaller ones as well.
Posted : 16/04/2011 2:38 pm
Marathons weigh a ton. Mine is 4400gm
Posted : 16/04/2011 2:49 pm
 DIS
Depends what Marathons you look at. The extreme for 40c (just checked web site) come in at 525g per tire. Some of the tires in the Marathon range are very heavy, these ones are at at the lighter end of the range.
Posted : 16/04/2011 2:57 pm
*ironic "heh"* I meant 400gm and furry muff re. the light marathons.
Mine turned out to measure 35 rather than 42, so it's going back ๐Ÿ˜ก I may try a Jones 1.8 and trim the knobs down ๐Ÿ˜€
Posted : 18/04/2011 9:58 am
