Can you ream the be...
[Closed] Can you ream the bearing seat for a carbon frame with an internal headset?
As above really?
Posted : 12/02/2020 2:04 pm
not really
Posted : 12/02/2020 2:06 pm
Why would you want to?
Posted : 12/02/2020 2:08 pm
to fit an angle set or some such.
Posted : 12/02/2020 2:13 pm
You can clean up the resin, I wouldnt want to cut into the carbon.
Posted : 12/02/2020 2:29 pm
New Carbon frame and attempting to install a CK Dropset 2 and there's about a 1mm gap between the griplock assembly and the top of the headtube.
Just had a look around and there seems to be others with a similar problem.
Posted : 12/02/2020 3:00 pm
Chris King spec normally spec the ream depth so you can check if it is compatible with your frame.
Posted : 12/02/2020 3:10 pm
I'd check your frame is manufactured within spec/tolerance.
Posted : 12/02/2020 4:58 pm
