Can you notice the ...
[Closed] Can you notice the difference?
 adsh
[#6874319]
A lot is made of the differences made by various design improvements etc. Have any of you ever noticed any of it? Here are the things I've never managed to actually notice myself.
15mm vs QR - never noticed any difference in flex
Taper vs straight - likewise
The spring of steel - not so I'd notice
The comfort of Ti - possibly a little bit
Pick up - what? I pedal, the wheels go round never noticed any delay.
Crank stiffness - from square taper through 24mm to PF30 never noticed a blind bit of difference other than non BSA BBs wear quicker
Am I insensitive or are we talking miniscule differences that most people wouldn't either?
Posted : 19/02/2015 1:39 pm
QR to 20mm - definitely.
Taper vs straight - no idea, still on straight steerers.
Steel - dunno, never ridden one
Ti - dunno, never ridden one
Pick up - i can tell when pawls are broken in my hub so maybe
crank stiffness - yup, saints made my feet hurt, xt's didnt.
Posted : 19/02/2015 1:43 pm
 JoB
15mm vs QR - yes
Taper vs straight - yes
The spring of steel - depends who made it
The comfort of Ti - depends who made it
Pick up - not really
Crank stiffness - yes
Posted : 19/02/2015 1:45 pm
15mm vs QR - yes, loads
Spring of steel/comfort of Ti - these are very dependent on the build. I've certainly enjoyed the spring from a nice steel frame, when it takes and gives back in a corner. But I've also had a Ti frame which was ridiculously harsh 😉
Pick up - yup
Cranks - yup, although only comparing square taper and HTII/X-type, and depends on the frame a lot too.
A lot of these things you really only notice when riding comparable bikes back to back though. It'd probably only be the 15/20mm vs QR that I reckon I might spot on a blind test, and that's definitely not certain!
650b to 26"? 😕
Posted : 19/02/2015 1:47 pm
QR - 20 NOPE and i even have a set of flexy sids
taper v straight - nope
Steel i can tell over things but may be the frame- it was more springy than my hydroformed alloy one but cannot tell it from carbon.
Pick up - yes v broken freehub in general from shimano XT to Hope XC and pro 2 NO
never used ti
I haver a square taper SS, XTR on shimano BB and XTR on Hope- cannot tell part in "feel".
Posted : 19/02/2015 1:48 pm
20mm vs QR - yes
Taper vs straight - not really
The spring of steel - yes but so many other variables
The comfort of Ti - again, on MTBs yes, less so on some roadies
Pick up - mebbe but it's not important
Crank stiffness - definitely
Posted : 19/02/2015 1:49 pm
15mm vs QR - yes
Taper vs straight - dunno, never ridden a tapered
The spring of steel - definitely good on some, definitely bad on others
The comfort of Ti - dunno never ridden a Ti
Pick up - only going from very cheap hubs
Crank stiffness - no, too many other things flex before the cranks (if we're talking crank arms)
Posted : 19/02/2015 2:05 pm
15mm vs QR
Yup obv. Come on
Taper vs straight
Yup
The spring of steel
Aluminium til I die
The comfort of Ti
As above
Pick up
Yup
Crank stiffness
Srsly?
Am I insensitive
Yup
Posted : 19/02/2015 2:06 pm
 JAG
I'm sceptical that anyone can tell.
To all that have responded "yes" above; would you be confident in a double-blind test? Can you really/honestly tell?
Or can you tell the difference when you know what you're riding?
15mm vs QR - Never compared 15mm & QR. 20mm & QR - big difference. 15mm & 20mm negligible
Taper vs straight - Yes very obvious if you try 2 otherwise identical forks.
The spring of steel - Yes
The comfort of Ti - Yes, although my Ti frame is apparently at the noodly/comfy end of the spectrum.
Pick up Yes. Very annoying on my DT 240s with the old 18T ratchets. riding tight, techy, thrutchy trails of trying to get started on steep tech climbs, it become blindingly obvious.
Crank stiffness. Notice it on a first ride when I change them, after that, not really. (although the set of Saints I had briefly were like standing on girders - quite impressive!)
Posted : 19/02/2015 2:12 pm
JAG - Member
Can you tell the difference between a 2ply DH tyre and a single ply xc tyre?
my bikes grow 'organically' by that I mean I purchase a new component to replace and old worn or broken onw; usually an upgrade is incorporated. I have done all of these and noticed a change to them all.
key difference my QR fork flexed so much my rotor scrapped the fork leg. didn't happen on QR15!
Posted : 19/02/2015 2:13 pm
I think you can notice quite a bit, but you also need to decide if it bothres you...
QR Vs 20mm: Yeah definately noticed, prefered 20mm but I was happy enough with QR's... 15mm? Meh, not much better or worse than 20mm, just another pointless tweener std.
Taper Vs Straight: a Bit I suppose, not really, dual crown forks though I really did notice the greater stiffness, but again all three are more than acceptable IMO...
[i]"The spring of steel"[/i] perhaps more the use of thinner walled tubing, not all steel is the same, steel frames with thinner walled tubes I notice the compliance a bit perhaps and obviously the weight, but a cheap, stiff frame will still do for me...
[i]"The comfort of Ti"[/i] TBH no idea, I've sat on one Ti road bike and rolled round a car park, no interest in owning one, so can't really comment TBH...
Hub Pick up? not really something I tend to notice, can't really see how it matters much TBH so long as it works.
Crank "stiffness"? yes, especially when I went from Square taper to HT2 although I believe this is more an improvement in the connection of the arms to the axle than the arms becoming stiffer...
I think it's as much about a rider's ability to adapt to the way a bike works as it is about the mechanical characteristics of the bike, there are very few
Unridable bikes...
Posted : 19/02/2015 2:14 pm
[i]Am I insensitive or are we talking miniscule differences that most people wouldn't either?[/i]
No. Yes.
Of course people will say they can feel the difference, becusae they've been told there's a difference, and that that difference is a good thing.
I'm not saying they're lying, they may actually think that they can, because we are very sugestoble creatures. However given the number of variables and the tiny absolute differences in stiffness, 'spring', etc etc, they really probably can't.
Posted : 19/02/2015 2:15 pm
15mm vs QR - Yes.
Taper vs straight - went hand in hand with an increase in stanchion diameter for me which is on the whole a very noticeable improvement. We're expecting more and more from single crown forks, they need all the help they can get. The increasing in headtube size and bearing size also has it's advantages too.
The spring of steel and the comfort of Ti. Not going to comment on that one.
Pick up - Yes. Technical climb, hop back wheel up ledge or rock split second to engage power to rear wheel to stop yourself sliding back. Crank turns a noticeable fraction of a turn before engaging... grrr! or put the power on suddenly and the crank turns a bit before engaging, very noticeable.
Crank stiffness - I remember having a pair of square taper FSA Power Pro cranks which you could see flex. New style cranks are stiffer and the BB/axle/crank design as a whole is a massive improvement.
Posted : 19/02/2015 2:18 pm
15mm/20mm vs QR - Yep, noticed a considerable difference between QR and 20mm. Have no idea why 15mm exists, other than to help Fox/Shimano differentiate between fork models.
Taper vs straight - Tough one. My 140mm 29er Revs are stiffer than my 150mm 26er 20mm Revs with a straight steerer. They're on a par with my old Pikes, but I don't know if that's due to to the steerer or the chassis itself.
The spring of steel - I wouldn't call it "spring", but my steel hardtail seems to dampen the terrain reasonably well. Apparently it would be better steel if it were made of posh steel and not made of not quite as posh steel.
The comfort of Ti - No idea. It's a lot of money though for something that'll have all the standards marketed out of it in a couple of weeks if Trek/SRAM have their way.
Pick up - Yep. I prefer a sharp pickup, anything else feels lazy to me.
Crank stiffness - Yes. I noticed a difference between old and new XT and SRAM BB30 cranks are stiffer still. Do I prefer a stiffer crank? Only if the ease of maintenance and BB bearing life is comparable with XT, otherwise it's not for me.
Posted : 19/02/2015 2:19 pm
My old steel Kona seemed to flex more under pedalling than the alloy bike that replaced it. In other words the alloy bike was better
[quote=IHN ]Am I insensitive or are we talking miniscule differences that most people wouldn't either?
No. Yes.
some people can isolate and identify small changes better than others.
If I can hear a high pitched sound and you can't does that mean I'm lying about it or my hearing is more sensitive than yours?
Posted : 19/02/2015 2:20 pm
 Spin
I think you'd need to try the different set ups back to back on otherwise identical rigs to be certain of the differences.
I wouldn't like to say if I could notice a difference with all of those, but I can say I'd prefer hubs without better pickup than the ones I have.
Posted : 19/02/2015 2:22 pm
IHN - Member
Posted : 19/02/2015 2:23 pm
Assuming this isn't a wind-up then yup no problem
Have got three (possibly four) bikes that are quite different and yet important components e.g.
forks
wheels
drivetrain
are all interchangeable. Can make any of them a little (or a lot) different simply by swapping components
Frankly I find it incredible how anyone could not notice the difference
Posted : 19/02/2015 3:40 pm
I can feel the difference in the back end of an inbred vs my soma b-side, that might just be new bike giddyness though! I should be able to see if I can feel a difference between an exotic carbon rigid with qr and a niner rdo (tapered with 15mm) at some point. Assuming my front brake finger stops hurting (PSA don't use fingers to slow rotors down).
Posted : 19/02/2015 3:43 pm
[b]QR to 15mm/20mm*[/b] - definitely yes, for shorter forks I notice but it doesn't bother me, for longer forks yes, my old QR 32s were awful!.
[b]Taper vs Straight*[/b] - yes, but it's quite subtle, I think the beefier headtube has a lot to do with it too.
[b]Steel[/b] - depends on how it's been built
[b]Ti[/b] - as above
[b]Pick up**[/b] - yes yes yes!
[b]Crank stiffness[/b] - yes I can notice it, but I don't care
* Riding a lot of Cannondales and Lefties in late 90's and mid 00's made noodly normal forks even more noticeable.
** I get really annoyed by my 240s with the standard ratchet, and even PRO 2's feel like there's a big dead zone, this probably comes form a life of trials when younger and havign 70+ POE for years. Not really an issue on the road or fast flat offroad but slow speed techy bits definitely like a quick pickup.
Posted : 19/02/2015 3:48 pm
15mm vs QR - no
The spring of steel - sort of
The comfort of Ti - sort of
95% of riders can't tell. It's a lot of money to spend so that 5% of people can notice.
Posted : 19/02/2015 3:49 pm
15mm vs QR - yes, very obvious
Taper vs straight - not so much
The spring of steel - too dependant on frame design
The comfort of Ti - as above
Pick up - yes, but not sure it bothers me
Crank stiffness - only from square taper to splined jobbies.
I recently built a wheel with a wider/ stiffer rim and I was gobsmacked how different it felt.
Posted : 19/02/2015 3:57 pm
15mm vs QR - yes, front and back
The spring of steel - impossible to compare without identically designed frames using different materials but from my experience yes there is a difference.
The comfort of Ti - never tried
Pick up - what? - Definately notice when switching beween bikes but soon adjust.
Crank stiffness - Crank arm no, BB yes - press fit and outboard is stiffer than square taper.
Could also add:
Stem stiffness - no
Carbon handlebar comfort - Slight improvement
Carbon seatpost comfort - not off road, on yes.
Indeed but we could easily test that
What may be happening is you can hear a noise that is not there as it seems a fairly even split between those who can tell and those who cannot
Take cranks
give they are made of metal the frame and the tyre will deflect , from the forces, when you pedal long before the crank will. Given this I remain sceptical than anyone can tell a crank is stifer. I doubt anyone here can actually genuinely flex the metal ALONE in either crank as the tensile strength will be measured in tonnes.
FWIW I have QR and 20 mm and the 20 mm has bigger stanchions and i still cannot tell. perhaps if i rode that bike with QR forks I could but I have never tried this
Posted : 19/02/2015 3:58 pm
15mm vs QR - Taper vs straight - Both of these upgrades happened simulateneously so impossible for me to say which had more, if any effect but the combination was noticeable.
The spring of steel - Yep, moved from an ally rockhopper to a Soul and yeah its definetly there! Was the most noticeable difference other than the geometry.
The comfort of Ti - Never tried...
Pick up - what? Oh hell yes, massive difference between the pickup on my bonty race wheels and my pro 2's the bontys feel like they take a good 20% roatation to engage whereas the hopes feel more like 5%. Very, very noticable for me.
Crank stiffness - only ever had HTII BB's so wouldnt know.
Posted : 19/02/2015 3:59 pm
15mm vs QR - twisting of lowers yes
Taper vs straight - not tried taper
The spring of steel - hmm possibly
The [s]comfort of[/s] spring of Ti - yes rear end of my Genesis ti is too flexy 🙁
Pick up - yes when on tricky stuff
Crank stiffness - nope but jammed on square taper cranks are an arse to remove
old, past it, over weight mainly wheels on the ground rider
Edit -
Stem stiffness - no
- you obviously never tried a standard size Ritchey WCS stem, was light but my god it was flexy when hauling on the bars 👿
Posted : 19/02/2015 4:03 pm
I've ridden saint cranks and XT cranks installed into the same bike, same pedals same shoes, same feet, on the same track, at the same speed a day or so apart.
Saints made my feet hurt, XT's didn't.
Posted : 19/02/2015 4:14 pm
15mm vs QR- damn straight. Though it doesn't really [i]bother[/i] me most of the time, I get used to whichever fork I'm riding pretty fast. Depends on the fork too, my QR revs were stiffer than a 15mm 32 because Fox are into being able to sell "improved stiffness" while Rockshox are more into making good forks.
Taper vs straight - too many other differences in my forks. I think my Pikes use the taper to save weight rather than add stiffs. My straight steerer lyriks are stiffer but then they weigh about 40% more, not useful.
The spring of steel - wouldn't call it spring, but yes, on a good, light frame. No, on a heavier frame. My BFe was as lively as a brick.
The comfort of Ti - yep but again depends on the frame, my Ragley doesn't have that much of it really, except when compared to my stupidly stiff Mmmbop. My old Soda was much softer and fitted the ti stereotype better
Pick up - Another "notice it but don't care"- I have a 10 degree upgrade in 2 of my DT hubs and standard in the 3rd, it only makes any practical difference if I'm ratcheting over things and even then it's not important. But it does feel nicer.Once it's past a certain point I don't think it matters
Crank stiffness - can't say I do these days but I think all modern cranks are probably sensibly stiff. Pretty obvious on my old square taper exages. I guess I notice flexy stuff, I don't notice the difference between 2 stiff but differently stiff things?
All the stiffness stuff is basically hung on some ropey perceptions of what's good and bad- stiffer isn't automatically better, it's just easy to sell. Unless you're making a steel frame when it's suddenly bad. Coming from a motorbike background, production bikes reached a highpoint of stiffness in about 2000 and then we went "**** me, that's too stiff" and backed off. Pushbikes still seem to be in the stage before that where everyone wants more stiffs but it won't go on forever.
Posted : 19/02/2015 4:17 pm
15mm vs QR: Nope
Taper vs straight: Nope
The spring of steel: Yep - even different builds of steel
The comfort of Ti: Yep (or steel for that matter)
Pick up: Yep
Crank stiffness: Not tried anything other than Shimano yet.
Posted : 19/02/2015 4:42 pm
20mm vs QR - totally
Taper vs straight - no idea, never ridden exactly the same fork between the 2 standards on the same frame
The spring of steel - prefer to call it flex, and yes but some steel frames have less flex than many Alu frames
The comfort of Ti - as above.
Pick up - definitely, even more so when just mucking around jumping, manualing etc.
Crank stiffness - yes.. definitely. HTII isn't inherently stiffer than SQ taper was though.. many Old skool SQ taper DH cranks were stiffer than XT HTII for instance. XT to Saint the difference is really noticeable.
Posted : 19/02/2015 4:48 pm
It's not on your list, but one of the biggest differences I've felt was going from 135 QR to 12x142 on a hardtail. Same frame & wheel but with the different dropouts and hub adapters.
I couldn't believe how much stiffer the rear end was.
Incredible how much less 'twang' there was from the back end.
It feels more direct on descents, especially berms but it's also harsher.
Posted : 19/02/2015 5:04 pm
Nah, they're not.. but you don't get on with the shape of the bars for the type of pushbikes where it has always been a consideration in build so it may well have passed you by. 😉
Posted : 19/02/2015 5:18 pm
Fair point chief, I was talking about mountainbikes but said pushbikes so yeah. And let's say "most people" instead of everyone. But [i]apart[/i] from that...
I can't remember any big mountain bike manufacturer saying "we've carefully made this bike more flexible because we think it's better for grip" anyway. Some individuals, like nico volauvent... But I think it'd take a pretty brave product lead and marketing team.
Posted : 19/02/2015 5:43 pm
Sell that to Surly 😉
Posted : 19/02/2015 5:59 pm
QR to 20mm: Oh my goodness, night and day
straight to taper: more of the above, fork goes where I point it.
Spring of Steel: hmmm, my Shan is the comfiest steel bike I've ridden, but it has no seat or chain stay bridges which probably make more difference
Spring of Ti: Yep, I can remember my first ride on a Hummer, checked a couple of times to see if I had a soft rear tyre, carpet ride bike.
Pick up; yep coming out of turns...Power! 😆
Crank stiffness: hmm not so much, went from I beam raceface turbines back to XT, and can't feel it TBH.
142x12: only a couple of rides, I'm not sure what's going on back there that's different, may let some pressure out of the tyre though
Posted : 19/02/2015 6:17 pm
Qr to bolt through? no
Tapered steerer? no
Steel springiness? switching from an inbred to a niner air 9 yes
Ti? not tried one
Pick up? only used shimano and hope so not really.
Crank stiffness? no
Posted : 19/02/2015 8:47 pm
15mm vs QR - yes, very clearly.
Tapered vs straight - again very clear esp on rigid forks - they flex on the blades rather than the crown steerer. On suspension forks, much less brake flutter, and twang through rocky sections.
Springiness is down to how the bike is engineered/designed rather than just a material. I just replaced an old alu SS frame with a steel one. Alu one was very noticeably softer (in every direction).
Tyre volume and pressure will make more difference though.
Pick up - swapped standard ratchet rings in one set of DT 240 hubs for the faster pick up - not fussed (and hated the noise).
Crank stiffness - not between HTII types I've tried, but did when I went from SqT to M950 XTR original HT cranks.
142x12 on suspension frames - definitely. Hardtails - probably not.
Posted : 19/02/2015 9:08 pm
QR both ends to bolt through both ends was a big improvement. Even noticeable while cornering.
Tapered steerer. Cant tell
Pickup. Not really, unless I really think about it.
Cranks. Yes.
Ti and steel. Not ridden a steel for 18 years so cant remember. Never tried ti.
Posted : 19/02/2015 9:24 pm
Some of you should learn to recognise hype 😀
Posted : 19/02/2015 9:36 pm
Bolt though is a big improvement over QR, especially on longer travel forks.
Not so sure about the tapered steerer. I can see it making sense on paper, I just can't feel it when riding.
Steel; I was surprised how much difference there was between my BFe and my Slackline 853. The BFe felt heavy, wooden and a bit dead / harsh. The Skackline felt much more lively but I wouldn't say it feels springy compared to an ali frame.
Not tried a Ti frame so can't comment.
Pick up. I've never had a hub with more than 4 pawls so they all feel the same to me.
Posted : 19/02/2015 10:38 pm
