can you mix and mat...
[Closed] can you mix and match different brand rotors aslong as its the same size?
my mate is gona buy some hope rotors for his juicy 5s will that be ok?
Posted : 16/04/2010 9:47 pm
I ran Shimano's with my M4's if that helps... ๐Ÿ˜•
Posted : 16/04/2010 9:49 pm
i thought avids for avids hopes for hopes formulas for formulas etc etc. lol
Posted : 16/04/2010 9:55 pm
if they fit, they'll er...fit surely, i.e. same diameter and width they should fit (unless one is 6 bolt and one is shimano spline fit)
Posted : 16/04/2010 10:00 pm
width doesn't matter much as all brakes adjust that
Posted : 16/04/2010 10:12 pm
 nuke
Use Shimano rotors with my Juicy 5s as I couldn't be bothered with centrelock converters on my centrelock hubs...found the shimano were as good if not better than the avid g2 they replaced
Posted : 16/04/2010 10:17 pm
I use whatever is around: Forumla, Avid, Hope, Shimano, generic cheapo ones - and I don't have any problems.
Posted : 16/04/2010 11:03 pm
I use Hope rotors with my Formula brakes. One issue you can get is if your pads are wider than the brake track on the rotor.
Posted : 16/04/2010 11:38 pm
Floating Hopes work in my Juicys and feel better than the original Avid discs. But, now fitted 2010 Fox TALAS forks and the spider doesn't clear the mounting post on the forks - due to running a King hub apparently so back to the Avis disc unfortunately...
Posted : 16/04/2010 11:54 pm
