Can you lace 26&quo...
[Closed] Can you lace 26" hubs on 27.5" rims?
Maybe a daft question, but I'd like to re-use my 26" hubs on a new 27.5" bike. Does anyone know if this is possible?
Posted : 02/06/2015 10:33 pm
Are they enduro-specific hubs?
Posted : 02/06/2015 10:34 pm
Yes, but not with the same spokes...
Posted : 02/06/2015 10:35 pm
A hub is a hub
(Assuming axle spacing 135/142/Boost/whatever they come up with next week is the same)
๐Ÿ™‚
No problem. The hub, spokes and nipples will fit. The spokes should come alive and grow to match the correct length of the 650b rim*.
* may not be true.
Posted : 02/06/2015 10:37 pm
yes, but a 29" rim won't fit
Posted : 02/06/2015 10:41 pm
What about 29" rims on 26" hubs? Will they cancel out and you end up with 27.5" wheels?
Posted : 02/06/2015 10:50 pm
Do you get the valve hole with new rims or is it extra?
Posted : 02/06/2015 10:53 pm
Posted : 02/06/2015 10:56 pm
 igm
We should introduce this thread to the crown race one.
OP you've had the sensible answer, stay tuned for much humorous stupidity
Posted : 02/06/2015 10:57 pm
I've had a cassette in the shop were the proper shimano label said 29er cassette... I fitted it to a 26" and it hasn't exploded (to my knowledge)
Posted : 02/06/2015 11:29 pm
What colour are the hubs?
Posted : 02/06/2015 11:48 pm
@ktow75 Ignore this piss takers. ๐Ÿ™„
They will be fine, you just need to fit longer spokes and 27.5" specific nipples.
Posted : 02/06/2015 11:50 pm
Pffffff nipples! ๐Ÿ˜†
Posted : 03/06/2015 12:44 am
If you graduate the spoke lengths you'll have biopace wheels.
Posted : 03/06/2015 12:56 am
But who will be liable for repaying the student loan?
Posted : 03/06/2015 5:42 am
You do have a magic cat though, don't you? You'll need one of those
Posted : 03/06/2015 5:59 am
Why not consider 650B rims instead of 27.5?
Posted : 03/06/2015 6:47 am
Come on guys. Stop taking the piss. OP, no you can't. The lower rotational speed of a larger wheel for the same linear velocity means that the balls in the bearings experience reduced centripetal forces, forcing them harder against the inner race. This means increased wear rate, (at best) or more likely bearing seizure.
Posted : 03/06/2015 7:05 am
Shimano made a 29er 'specific' slx hub a few years ago. Although i think that was more about them worrying about their freehub life/durability with what were then 'larger range' (11-36!) cassettes.
Whatever happened to the 29er specific saddle? (Not joking, this was in the proper bike news and everything).
Posted : 03/06/2015 7:20 am
 LeeW
I think Fizik make a 29er specific saddle.
Posted : 03/06/2015 7:25 am
You will be fine. Depending on the tyre width you may want to wait till Specialized release their low profile tyres for 2016. Im sticking with 26" till they sort that out
Posted : 03/06/2015 8:19 am
Extralite do 29er hubs
http://www.extralite.com/Products/HyperCamber2.htm
Posted : 03/06/2015 8:35 am
 igm
Tracey - presumably with those tyres you can just stick with the 26" rims and use a 0.75" bigger tyre to bring the 26" up to 27.5"?
26>>27.5>>29 without all that faffing swapping rims.
Posted : 03/06/2015 9:36 am
No. The lower profile helps with faster the cornering. They have been designed to work with the new wide rims. Will be able to stick 650b on the back of the Enduro without swapping the back end
Posted : 03/06/2015 10:28 am
a 26" hub will require very short spokes to lace to a 27.5" rim - approximately .75" long. You may need to have some custom threaded if you can't find any off the shelf.
Posted : 03/06/2015 10:40 am
 igm
Tracey
Doesn't that turn the effective outer diameter back into a 26"?
[cynic] So the next great development in MTB wheels is reinventing the 26er, but based on a larger bead size? Interesting. [/cynic]
Posted : 03/06/2015 11:18 am
