Can you convert a r...
[Closed] Can you convert a rear Hope BULB to 142x12mm?
I suspect the answer is no, but after reading threads about converting the front one to 15m I thought I'd see if anyone has done it to save buying a new wheel and wasting these perfectly good ones.
Posted : 07/10/2012 8:28 am
If you have a lathe and a mill anything is possible.
Ive done 150 conversions on a standard bulb but it isnt pretty- but neither was the bike it was going on ๐Ÿ™‚ this was before 150 hubs were common place.
I guess it depends if the pro 2 kit could be adapted but i doubt it.
Posted : 07/10/2012 8:32 am
Not officially you can't. as mentioned above, if you've got the kit then anything is possible!
Posted : 07/10/2012 8:34 am
