Can you convert a F...
Can you convert a FOX fork from remote lockout to, errr, non-remote lockout?
5 Users
Hi all,
I immediately dislike the remote lockout feature.
Can I convert it to a manual lockout without much hassle?
I found this thing:
It's not a massive issue, but if I could change it relatively easily, for the sake of simplicity, I would.
Cheers,
FM
Posted : 27/04/2024 1:04 pm
I converted my Fit4 remote lockout to a manual one. Took about 10 mins to do. Fox said I needed 2 kits; one with the lever and one to replace the top of the damper assembly that screws into the stanchion. I just used the first kit with the lever which was about £15 and it works fine.
No idea about the Grip damper though.
Posted : 27/04/2024 2:29 pm
I just took the cable off mine and left it at that. Never used lockout on a fork anyway and ‘upgrade’ was free.
Posted : 27/04/2024 3:50 pm
Yep, easier on a grip as it's just the parts above.
Fit4 now has a different u-cup for remote lockout forks that's a slightly different size, but importantly deletes the indent spring/bb pocket so you can't have the "3 clicks" without replacing the cup as well.
Grip doesn't need 3 specific positions as it's continuously variable compression at all positions though so that wave washer does the job.
Posted : 27/04/2024 4:32 pm
If you're selling on the remote lever afterwards, let me know. Mine is currently held together with random bolts and washers.
Posted : 28/04/2024 9:17 am
Hi mate, are you based in the UK? Where did you get the parts? Thanks!
@martinhutch, will do!
Posted : 29/04/2024 9:40 am
