can I use sram powe...
[Closed] can I use sram power links on an xt chain ten speed
As above. Just converted bike to ten speed just wondering if anyones uses sram's split links on shimano chains? Been using sram 9 speed links on shimano chains for years (one of me bikes got four on one chain!) without any issues just wondering if ok on ten speed
thanks ๐Ÿ™‚
Posted : 20/07/2014 10:53 pm
Probably best to fit a 10 speed KMC split link as Sram power lock links aren't strictly reusable.
Posted : 20/07/2014 10:57 pm
Yes - although SRAM 10 speed links aren't designed to be reused, so can be fiddly - use a different brand like KMC
Posted : 20/07/2014 10:58 pm
+1 for the KMC suggestion
Posted : 20/07/2014 10:59 pm
Ok good stuff didnt know that about the sram links. KMC it is then
cheers men ๐Ÿ™‚
Posted : 20/07/2014 11:00 pm
 chip
I have recently started using kmc links on my xt 10 sp chains.
After going from triple to double to single ring and then a couple of mech changes all in a short space of time left me with 6 connector pins in one chain.
No problem with the kmc links.
been using a 9spd powerlink on an XT 10 spd chain, cassette, mech without any issues, will probably change to a 10 spd when i can be bothered
Posted : 20/07/2014 11:02 pm
I have used a 9SPD SRAM link on both Shimano and SRAM 10SPD chains with no issues...not buying SRAM 10SPD ones as I'll not get them off without buying yet another tool.
Posted : 20/07/2014 11:05 pm
Fenboy:
Do you do much climbing as in put a lot of stress on your chain n link?
Didnt realise you could use 9 speed linkson ten speed chains.
Posted : 20/07/2014 11:08 pm
 chip
I can see why this would work because the internal spacing is the same and the difference in outer sizing can not be more than the amount a connector pin sticks out once snapped off.
Cool
I got some new 9 speed ones so give that a try tomo
thanks for some good advice all feel like im in the knowa bit more
bit peed off going ten speed anyway my sc superlight still 9 speed and faultless but lbs sorta advised me its the way forward
Posted : 20/07/2014 11:11 pm
