Can I use a sram cassette on Shimano STI shifters and 105 rear mech ?
what would the issue be ?
Are the internal drive profile the same to fit onto a hope free hub ?
I have a KMC chain - which ive always used with Shimano also - but now want an 11-36 sram rear cassette.
Issue would be your rear mech probably won't clear a 36T cassette.
The Sram cassette will work perfectly with Shimano and KMC but as noted above, depending on your cassette size, 105 rear mech may not have enough length.
yup. Is it 11 or 10 speed? If 10 speed then a 9spd Shimano MTB mech will work with your 10spd road shifters and the cassette.
it is 11 speed
Ultegra long cage RD-6800 defo works with SRAM11-36, so a long cage 5800 *should* work. If not, you'll need a goat link type thingy.
richardthird - Member
Interesting, it's only rated for 32 max. What front chainring set up do you run?
Compact and also on a 1x 38t. Also almost takes 11-40 Sunrace on the latter with a longer B-screw, but faultless with goat link.
whats the goat link ?
I have a double cx set up - I will have to check the exact 105 rear mech I have
