I know the sram shifters are 1:1 but as the mech just moves as the shifter dictates is there any reason this won't work?
Posted : 03/02/2009 3:34 pm
the actuation ratio must match between shifter and mech.
You can use SRAM Attack shifters with shimano mechs but not the numbered ones (X9, X0)
Posted : 03/02/2009 3:35 pm
If the shifter has a name (Attack, Rocket etc) - yes
If it has a number - no
Posted : 03/02/2009 3:36 pm
Yes, mech is designed to work with the same pull ratio as the shifters, so change one and things don't tie up.
Unless you have SRAM attack/rocket shifters, its a no-go.
Front mech will work with SRAM or Shimano shifters.
Posted : 03/02/2009 3:37 pm
OK. thanks. Shifters are Sram X7 so that's a no then. Cheers.
Posted : 03/02/2009 3:40 pm
have a functional but battered x7 rear mech if required - click on my name to e-mail me
Posted : 03/02/2009 3:41 pm
junkyard ygm
Posted : 03/02/2009 3:48 pm
