Can I use a 11-32 c...
[Closed] Can I use a 11-32 cassette with a short cage rear mech (hardtail)?
[#4865211]
As above thanks
Posted : 12/02/2013 9:20 pm
I do.
Single or double front rings yes?
Posted : 12/02/2013 9:23 pm
How many rings up front?
oops 3
Posted : 12/02/2013 9:48 pm
Yes, unless you cross your gears up (big/big or small/small combinations) On my cross bike I run a road triple (30/40/52) with a 12-27 cassette and a super short mech and it's worked fine for 6 years.
Posted : 12/02/2013 10:07 pm
Personally I wouldnt, as you do forget what gear youre in sometimes when you should shift front down you shift rear up... graunch
Posted : 12/02/2013 10:09 pm
I do, haven't had any problems (touch wood).
Posted : 12/02/2013 10:13 pm
Ok cheers.
Posted : 12/02/2013 10:15 pm
I run a 11/32 9 speed cassette with a triple 22/32/44 chainset
I hardly use the 44 so no problem but in the big ring towards the top of the cassette could be disaterous
Posted : 12/02/2013 10:21 pm
Yep, have done since my first Clockwork in '93. Just set the chain so it will [i]just[/i] accommodate big/big so it doesn't all jam up if you accidentally shift into big/big. The chain will be slack in small/small, but how often do you go below the 5th sprocket before going back to the middle ring?
Rob
Posted : 13/02/2013 10:24 am
 will
Yes:
Although I snapped the rear mech. Always felt there was too much pressure running through the gears, so now have along cage XT.
Posted : 13/02/2013 12:58 pm
Short cage X7 with a 32T chainring and 11-32 cassette works great for me.
Would not use it with a double or a triple or on a FS though.
Posted : 13/02/2013 1:07 pm
