Can I use a 10spd c...
[Closed] Can I use a 10spd clutch mech on a 9spd? Or...
 hora
Or...what 9spd rear mech (short cage) 34T cassette best mimics the clutch?
Posted : 30/03/2014 9:58 pm
You can use a 10sp shimano mech with 9 speed SRAM shifters apparently. The trick is to use a 6mm packer to lift the cable off the mech. So the cable bolt clamps the cable against the packer/ washer, which sits between the cable and mech. There was a thread on here a few weeks ago about it. Haven't tried it yet, but intend to
Posted : 30/03/2014 10:09 pm
I have an adapter for the mech you can have if you like Hora? Your in the peak arnt you?
Posted : 30/03/2014 11:28 pm
 hora
Currently using a SRAM Attack shifter. I say 'currently'- its probably been on my bikes 5yrs+.
Would that be ok? I 'think' early Sram were 1:1?
Im in the Peaks both days next weekend ๐Ÿ˜€
Posted : 31/03/2014 6:50 am
Won't work with attack, needs to be normal sram
Posted : 31/03/2014 6:53 am
 hora
Cheers what actuaction is Attack? (This is all new to me as my shifter is mated to my 2002 XTR mech)
Posted : 31/03/2014 6:57 am
Same as shimano
Posted : 31/03/2014 7:08 am
http://m.pinkbike.com/forum/listcomments/?threadid=106197
Posted : 31/03/2014 7:09 am
 hora
Question/thinking- its a 1 ring set up, surely running a SHORT cage normal mech that can reach 34 tooth rear will massively help as it'll lessen chain slap/growth?
Posted : 01/04/2014 8:44 am
yep, also add an extra twist of the mech (undo stop and twist, put stop back) to make the spring stronger
Posted : 01/04/2014 9:14 am
